Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Pansat and gtools1.86
Author Thread: Pansat and gtools1.86
Username: Bluejays
Post Number: 9
Some posts indicate to only use BL bins/exe for Pansats. At dsscommunity , I cannot download the file with the new echostar package and gtools. There is another 1.86 gtools zip file in the files forum. Would this be the same file but not labelled BL.gtools.1.86zip? Any direction would help.
LK
BL = blacklist,a very well known script writer...gtools is a program to edit and install your channel list..U can use any gtools there...But the echostar package is the best and does download...many use it and downloaded it from there..
Username: Bluejays
Post Number: 10
ok I'll try again. Thanks for your input.
HI, I HAVE A NEW VERSION FORTEC RECEIVEIR BUT I CAN'T FLASHED, THEN T TRAYED OLDER VERSION THAN THIS ONE (SEPTEMBER 2004)AND IT'S WORKED MY QUESTION IT'S FOR THE FIRST RECEIVER THAT I CAN'T FLASHED, HERE IS SOMEONE TO HELP PLEASE0. THANK U.
Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Pansat and gtools1.86 [ « Previous ] [ Next » ]
