Thread: Help please, DiSEqc switch problem |
New member Username: Jays247
Post Number: 1 Registered: Jan-05
| Posted on Sunday, February 20, 2005 - 06:27 pm: |
I have a DiSEqc switch, I am using two dishes, 1 is pointing to echo6/8(110) and the 2nd is pointing at echo7(119). Im using a Fortec lifetime Ultra rec. Now the only sat I can view is the one that is plugged into LNB#1, the error on the screen is no signal. Can someone help me out please, Thx. |
Silver Member Username: Jmill1948
Chester,
Va
Usa
Post Number: 539 Registered: Apr-04
| Posted on Sunday, February 20, 2005 - 06:41 pm: |
Check the disque setting in the options......... |
Unregistered guest |
| Posted on Friday, February 25, 2005 - 02:16 pm: |
I recommend you to change the positios in the connector... This is....instead No. 1 to 110 and, No. 2 to 119, change it No. 2 to No. 3 in the Diseqc and that`s it. If you still having problems, first you have to test each LNB directly to your system (without switch). Good luck |
New member Username: Sal24
Post Number: 1 Registered: Feb-05
| Posted on Friday, February 25, 2005 - 06:01 pm: |
I have a RCA dish with 3 LNB integrated.. Can I use it with the new fortec 2500 lifetime to get the two signals (110 and 119 d.) at the same time or I have to use the switch...? How...cause I already connected but only one signal is received... |
| Posted on Saturday, February 26, 2005 - 05:36 pm: |
Can someone tell me what is the differance between a 1.0 switch and a 1.2.....sw21-sw34 |
