Thread: Panasonic DMR-E50 Problem...Please help |
New member Username: Buch69
Post Number: 1 Registered: Feb-05
| Posted on Sunday, February 20, 2005 - 06:14 pm: |
I purchased a Panasonic DMR-E50 DVD recorder about a year ago. Today the slanted circle which comes on everytime you use it is stuck in a continuos loop. Nothing is happening except for the circle going around. Any ideas ? Thanks, Jack |
New member Username: Josh7
Post Number: 4 Registered: Feb-05
| Posted on Tuesday, February 22, 2005 - 08:45 am: |
Have you tried a lens cleaner? Is this happening with a disc that you know it played previously? |
Unregistered guest |
| Posted on Friday, March 25, 2005 - 03:42 pm: |
i have accidentally changed my settings to remote 3. i can not use the remote at all now. the display just reads remotedvd3 now.any ideas on how to change it back to remote 1 thanks chris |
Silver Member Username: Samijubal
Post Number: 734 Registered: Jul-04
| Posted on Friday, March 25, 2005 - 04:10 pm: |
You don't even say what recorder you have. On a Panasonic you hold power on the remote and push whatever number button you want the code set on. To change on the recorder it's done in the on screen menus. |
| Posted on Monday, May 23, 2005 - 11:10 am: |
Same problem as hazzer. I've got a Panasonic DMR-E50. I changed the remote code accidentally to DVD 3. The manual says hold down ENTER on the remote and the number you want to change to similtaneously (in my case "1") for 2 seconds. I tried this and nothing happened. Also tried as you suggested above (Power button + 1) with no luck. Any other suggestions? |
| Posted on Saturday, June 25, 2005 - 11:24 am: |
Panasonic DMR-E50. I took it out of the box and hooked it up. I cannot get anything to come across my TV from the unit. I have no idea which RF station to tune it to. i have tried 3-4 and all the others. It does not play either DVD or TV stations. The unit does allow cable to go through with no problem. In other words I can receive TV with the DVD recorder hooked up. The set up scan of stations took place and the time and date are show on the LED screen. What should I do to get it to play. I unplugged it for 1 minute and plugged it back in nothing changerd. Help! I have been on hold to Paansonic for 45 minutes. Their website does not have information on this older model. I bought it brand new. |
Gold Member Username: Samijubal
Post Number: 1224 Registered: Jul-04
| Posted on Saturday, June 25, 2005 - 12:18 pm: |
DVD recorders don't output through the RF connection, all they do is pass through the incoming signal. You need to use an s-video cable or RCA jacks. |
| Posted on Saturday, July 09, 2005 - 08:05 am: |
I bought the panasonic dmr es 10. when I make recordings of some dvds, I can play them on the same panasonic , and on any other dvd player. But when I make some recordings of my video tapes on a dvd, I can only watch them on the Panasonic only and on the other dvd players no. What is my problem? Can anyone help me pls. sorry for my english.
Post Number: 1288 Registered: Jul-04
| Posted on Saturday, July 09, 2005 - 11:14 am: |
Are you finalizing the discs? |
| Posted on Monday, July 11, 2005 - 05:21 pm: |
yes. when i finilize from dvd to dvd it is ok. but when i finilize from vhs to dvd i cannot play the new dvd on other dvd player, on the same panasonic
| Posted on Monday, July 11, 2005 - 05:22 pm: |
only on the same panasonic I can play them. |
Post Number: 1300 Registered: Jul-04
| Posted on Monday, July 11, 2005 - 05:51 pm: |
What speed are you using? What brand of discs? It shouldn't make any difference what the source is. |
| Posted on Thursday, July 28, 2005 - 09:43 am: |
Help! I cannot get a channel on the dvd. It says No signal! but I already connected the cable directly to the dvd. what should i do? please help. |
| Posted on Thursday, August 11, 2005 - 02:39 pm: |
I Recently bought a panasonic DMR-E50 i didnt get any instruction on how to use it does anyone know anysites i can downland instructions i've tried the panasonic site but they dont reconise the model number when i press a botton on the dvd control it reads Remote dvd 2 what does that mean |
Post Number: 1432 Registered: Jul-04
| Posted on Thursday, August 11, 2005 - 05:32 pm: |
Probably means the remote code is 2. I think there are 4 different codes it can be set on in case you have more than one Panasonic unit. What matters is that the remote and recorder are both on the same code. |
| Posted on Saturday, August 13, 2005 - 11:43 am: |
how do you Change the Code on the remote as i cannot use it on the dvd recorder i'm having problems recording things on to a dvd, the recorder keeps switching it self off and it reads an error has accured press entre but it wont let me until i change the code! |
Post Number: 1447 Registered: Jul-04
| Posted on Saturday, August 13, 2005 - 12:22 pm: |
On the older recorders, you hold the power button and press one of the number buttons, 1 for code 1, 2 for code 2, etc. |
| Posted on Sunday, August 14, 2005 - 12:47 pm: |
I don't know how old mine is but i'll give it a try thanks for that do you if the recorder can record VHS on to and does it do all VHS or any Vhs? |
| Posted on Sunday, August 14, 2005 - 12:51 pm: |
I don't know how old mine is but i'll give it a try thanks! |
| Posted on Sunday, August 14, 2005 - 12:52 pm: |
Post Number: 1451 Registered: Jul-04
| Posted on Sunday, August 14, 2005 - 01:30 pm: |
Any recorder will record VHS. Connect with RCA jacks and set the recorder on whatever input you used. |
| Posted on Sunday, August 14, 2005 - 02:24 pm: |
I've managed to get the control to work but everytime i try to redord on to a dvd it only records for about 2 minutes and then switches it self off and a message comes up on the screen saying please check disc! |
| Posted on Sunday, August 14, 2005 - 02:25 pm: |
| Posted on Sunday, August 14, 2005 - 02:27 pm: |
| Posted on Sunday, August 14, 2005 - 02:30 pm: |
i've manage to get the control to work but when i try to record something to dvd a message comes up reading please check disc? |
Post Number: 1453 Registered: Jul-04
| Posted on Sunday, August 14, 2005 - 09:47 pm: |
Are you trying to use + discs? If it's an RW it has to be formatted first. I've seen a couple of cheap DVD-R discs that won't work in standalones. |
| Posted on Monday, August 15, 2005 - 01:25 pm: |
I'm using princo dvd-r discs it wont allow me to record on to them. |
Bronze Member Username: Vibr84me
Winnipeg,
Manitoba
Post Number: 14 Registered: Aug-05
| Posted on Monday, August 15, 2005 - 01:59 pm: |
If anyone is interested I am selling my Panasonic DMR-E85H for 375 Canadian with high end cables - I've upgraded to the big daddy and don;t have the space in my rack for it. - I have used +R and -R with no problems |
Post Number: 1456 Registered: Jul-04
| Posted on Monday, August 15, 2005 - 06:11 pm: |
Princo is bottom of the barrel, try better discs. |
| Posted on Tuesday, August 23, 2005 - 12:17 pm: |
somebody can help me, need the (digital) manual for the ES10 with scart conn. lost me papers url's welcome |
Melissa G Unregistered guest |
| Posted on Thursday, August 25, 2005 - 02:42 pm: |
I had this problem with my recorder also. I was using the same discs I had used previously with no trouble at all, then all of the sudden it wouldn't record anymore. I tried everything, but had no luck. I left the recorder alone for the night and the next afternoon decided to try it and it worked like always. I realized that it was overheating because I was using it so much. Now when I record a dvd I let it cool down for a couple of hours before I use it at all. I completely turn off the recorder and use another television and I haven't had one bit of trouble since. Hope this helps you. |
New member Username: Kinseeker
Post Number: 1 Registered: Sep-05
| Posted on Monday, September 19, 2005 - 04:24 pm: |
I have a Panasonic DMR-E50. I am having the same problem as others - that is I can't get the code right to make the remote control work. I tried holding the enter and 1 together. That didn't work. I tried holding the power button and 1 together. That didn't work. The remote won't work at all. Any other suggestions? |
Post Number: 2 Registered: Sep-05
| Posted on Monday, September 19, 2005 - 06:08 pm: |
I finally got someone at Panasonic and he explained to me how to fix it. Sorry for my previous post. |
| Posted on Saturday, October 15, 2005 - 06:51 pm: |
have dmre50 recorder lost the manual ,forgot how to finalize my dvd . currently recorded 3 shows totaling 6 hrs . dvd did record but only could watch on that recorder how do you finalize the disc so it could be played on most dvd best ira |
Post Number: 3 Registered: Sep-05
| Posted on Saturday, October 15, 2005 - 07:04 pm: |
Go to http://service.us.panasonic.com/operman/ and enter your model # to download the manual. |
New member Username: Tengu
Post Number: 2 Registered: Oct-05
| Posted on Saturday, October 15, 2005 - 11:29 pm: |
Why can't I schedule record from my scientific atlanta (Eplorer 3250) digital cable box (Time Warner service) to my Panasonic DMR ES20? |
| Posted on Thursday, October 27, 2005 - 06:07 pm: |
Please, I need a big help. I live in Brazil and my father bought a Panasonic DMR-ES20. It works only in Region 1 and I'm in Region 4. What can I do ? There any code to make it multi-region ? Thanks for any help |
