Thread: Cable Converter |
Bronze Member Username: Dmwiley
Post Number: 14 Registered: Feb-05
| Posted on Sunday, February 20, 2005 - 11:14 am: |
Does anyone make a device that will convert a coax signal (from cable television) to an S-video output? |
xvxvxvx Unregistered guest |
| Posted on Sunday, February 20, 2005 - 07:40 pm: |
You need a tuner, there is no other method since all the signals must first be seperated prior to converting them to S-Video one by one. This is what your cable box does, the tuner in a DVD recorder, a VCR and a TV. xvxvxvx |
Post Number: 15 Registered: Feb-05
| Posted on Sunday, February 20, 2005 - 07:56 pm: |
Thanks for your response. However, I do own an av selector by JVC that converts composite signals to S-video (separates luminance & chrominance). I thought maybe it was also possible from a coax signal. But I guess not without a tuner of some sort. |
| Posted on Monday, February 21, 2005 - 12:04 pm: |
I have a Toshiba t.v. that will not allow me to view channel 3 (a local station) and I can't seem to program the channels so that it will come in. Is there some reason that channel 3 in particular would not be active? |
Post Number: 22 Registered: Feb-05
| Posted on Monday, February 21, 2005 - 05:09 pm: |
Are you using cable, satellite ota antenna (outdoor or indoor)? Need more info. |
