Home > Message Board > Home Video > Satellite TV > Archive through February 20, 2005 > Buying a CATV Converter??
Author Thread: Buying a CATV Converter??
Just Wondering
Here's my (long) story:
I ordered Comcast digital cable. I was not impressed with the picture quality, so I cancelled it the next day. The cable guy came out, collected the equipment, and I was never charged a thing.
I went without TV for awhile, then decided I would at least plug into the cable outlet so I could get local channels clearly...you know, use the existing wiring as an antenna. By doing this, I noticed I got channels 1-120, which is extended basic cable. Seems it never got disconnected.
Then I was curious if the REST of the cable channels were also still connected -- so I borrowed a neighbor's comcast cable box. I hooked up the box and premium channels WERE still being piped to my house.
So, if I am un-officially still receiving these channels, can I just buy a cable box like my neighbor's -- and will it work? Or do I need to have any box I buy activated by the cable company?
Username: Analman_returns
Post Number: 71
HOW MANY TIMES YOU GOIN TO ASK THIS QUESTION.
Just Wondering
I see you're one of the more helpful contributors on this forum.
Obviously you don't know the answer.
Thanks for your wisdom, sphincter boy.
jojo49
no not at this time, nothing to buy
Home > Message Board > Home Video > Satellite TV > Archive through February 20, 2005 > Buying a CATV Converter?? [ « Previous ] [ Next » ]
