Home > Message Board > Home Video > Rear Projection TVs > Archive through February 25, 2005 > Cleaning screen of Mitsu wd-52725?
Author Thread: Cleaning screen of Mitsu wd-52725?
Username: Ripsid
Purgatory, NJ
Usa
OK, what is the BEST way to clean the screen (it comes with the diamond shield) of my Mitsu dlp? Someone told me a damp cloth is all you need, but that just doesn't sound right to me.
Anyone?
10X
SID
Username: Paul_ohstbucks
Post Number: 80
I also have a Mitsu with the diamond shield, and I think a damp cloth is the way to go, but you should refer to the manual to be sure.
Keep in mind, it's just plexi-glass. Dont go scrubbing it real hard or you might put streaks on it.
BTW....I like the Idea of the diamond shield, but geezz....couldnt they have made it a little less reflective??
I was actually considering removing mine, but saw that I will lose some contrast by doing so, so I decided against it's removal.
Username: Ripsid
Purgatory, NJ
Usa
I have to agree about the glare, but I do like it because of mykids! Hell that's why I need to clean it, there's finger prints on it!
It is a good idea, but they could do a better job of it. I checked the manual on line and it does say, damp cloth. I worry about scratching, hell I used a no scratch cloth on my hockey visor and it was ruined! Thanks Paul!
SID
Home > Message Board > Home Video > Rear Projection TVs > Archive through February 25, 2005 > Cleaning screen of Mitsu wd-52725? [ « Previous ] [ Next » ]
