Thread: Dishnet hits and info |
| Posted on Friday, February 11, 2005 - 12:02 am: |
whats going on with dishnet? my lock has kicked in about 5 times tonight. we need to have a thread that keeps people upto date on ecm's or other info going on with Dishnet. this is it. spread the info. all i have now is a "rumour" that Dishnet is going down for good sometime this year. and today they seem to be hitting like crazy. good thing for digital locks. |
| Posted on Friday, February 11, 2005 - 10:12 pm: |
Yea man my dish got hit so many times too i'm a beginner i need help .. i have to go very far to fix my receiver . and i'm getin tired of it ... iwant to do it myself can anyone help me? |
| Posted on Friday, February 11, 2005 - 11:11 pm: |
Should read before U ask...read the thread here titiled "Dishnet and Bev Info"...U would have/will see this post there by me.. -------------------------------------------------------------------------------- To fix your receiver from the recent ECM: 1. connect JTAG to receiver. 2. open up Jkeys2.99. 3. enter flash programming 4. On the full line select the down arrow and select the SA address for your model. 5. Make sure the SA address is displayed and then select erase, you get a verification popup asking if you want to erase theis sector. 6. Place receiver in the stream, without the smart card. The unit will flash the power light a feww times then go solid, don't worry about a picture at this point, you won't get one. 7. When the update is complete, the receiver will be displaying the system information screen, now verify the loacation ID has changed to some thing other than 000001.Also verify the software version has the -N and Not the -F, if it's a dash F, then more work is required. The eeprom is corrupt and requires rewriting. 8. If all the info is correct, place smartcard in it and Watch tv. 2700 = address SA5 (512 k tsop) 2800 = address SA5 (512 k tsop) 3700 = address SA5 (512 k tsop) 3800 = address SA30 (2 meg tsop) 3900 = address SA30 (2 meg tsop) 4700 = address SA30 (2 meg tsop) 4900 = address SA30 (2 meg tsop) 301.010 = address SA3 in flash 1 SA15 in flash 2 (2x2 tsops) 301.013 = address SA3 in flash 1 SA15 in flash 2 (2x2 tsops) 501=address SA54 (4meg tsop) BTW...ECM's almost daily since Superbowl.. |
| Posted on Saturday, February 12, 2005 - 09:55 am: |
DISH/BEV IRD Error Codes Below is a list of error codes generated by the IRD with their definitions. DishNet Error Codes 002 The satelite has lost the signal, please use up or down key. ... No signal being recieved. Could be that Sat moved, bad weather, New spot beam has removed signal from your area, bad cable connections, Bad switch 004 check switch 005 Your smart card does not currently have authorization to view or purchase this program. ... Give it time, it will eventually get the new decrypt keys 009 013 This is a subscription channel which has not been purchased. 015 Acquring satellite signal. Please wait. 019 The smartcard is not inserted correctly. ... Either cam looped, in IRD wrong, or making bad contact 020 The smartcard currently inserted is not valid for this receiver. ... The Wrong ird number was put on the card 021 Smartcard is not inserted into the receiver. ... Put smart card in. If your cards in you have a hardware problem 022 Your receiver has not yet been authorized . ... Your IRD # and boxkeys are 00'd out or wrong or you ird status byte is set at 80 (Suspended) needs to be set at 00 (normal) 023 Unable to acquire program guide information. ... No satallite signal 024 unable to read from memory 025 satellite signal has been lost 043 053 061 Vital programming will now be downloaded into your receiver. Do not disturn or unplug it. 081 Dialing out. please wait. 083 Dial-out failure. The receiver is unable to dialout. 104 A serious problem has been detected in your receiver . Please call: 1-888-884-3759 303 Your receivers memory is now being programmed. Do not disturb or unplug your ird while the green froint panel light is blinking. 150 "A SERIOUS PROBLEM HAS BEEN DETECTED WITH YOUR RECIEVER: PLEASE CALL 1-800-334-7496." ... Your ird's firmware is detecting the lock, unlock or go back with your irds firmware... DO NOT CALL 151 "A SERIOUS PROBLEM HAS BEEN DETECTED WITH YOUR RECIEVER: PLEASE CALL 1-800-334-7496." ... Usually do to a bad lock installation or the old lock installation, turn off IRD and unplug. Check for info on how to correct before doing anything. DO NOT CALL 152 "A SERIOUS PROBLEM HAS BEEN DETECTED WITH YOUR RECIEVER: PLEASE CALL 1-800-334-7496." ... You have been hit by an ECM targeting the EEPROM, turn off IRD and unplug. Check for info on how to correct before doing anything. DO NOT CALL 153 "A SERIOUS PROBLEM HAS BEEN DETECTED WITH YOUR RECIEVER: PLEASE CALL 1-800-334-7496." ... You have been hit by an ECM targeting the TSOP, turn off IRD and unplug. Check for info on how to correct before doing anything. DO NOT CALL 155 outdated tsop hard lock nag ...Your ird's firmware is detecting the lock, unlock or go back with your irds firmware... DO NOT CALL 349 "You are attempting to use a version of smartcard that is incompatible with this receiver." ... IRD firmware is anti Rom2/Rom3/Rom10... need to do the VIDMOD
My Dish went Nuts Unregistered guest |
| Posted on Saturday, February 12, 2005 - 11:06 am: |
_________________________________________ ERROR ..........153 _________________________________________ A serious problem has been detected with your receiver Please call 1-800-334-7496 _________________________________________ |
hughnohoo Unregistered guest |
| Posted on Sunday, February 13, 2005 - 11:58 am: |
My Dish Went Nuts: you have just been ecm'd. Follow LK's advice in the post above. Emu users fix already done, plastic users need to wait a little for the fix. |
New member Username: Wyrtwister
Post Number: 2 Registered: Feb-05
| Posted on Sunday, February 13, 2005 - 12:17 pm: |
Try Free To Air , no card to mess with & Charlie can not damage the receiver . Wyr |
afroman Unregistered guest |
| Posted on Monday, February 14, 2005 - 01:34 am: |
fta sucks no program guide how the hell do you know whats on? anyways i got a new script for my dishnet and it is not locking up every hour. runs fine now. i would still like to know how bad the ecm's are.
madmarty Unregistered guest |
| Posted on Thursday, February 17, 2005 - 08:27 pm: |
LK, the address to erase on a 501 is sa60. sa54 worked on the old software. |
Post Number: 4 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 06:28 pm: |
The PCI cards have EPG's . Depending on the software , Ecms , 2 - 4 months , maybe . Just got 2 sick Fortec Ultras off of EBay . Jtaged them back to working & flashed it to a Pansat 2500A ( had 2 Pansat remotes on hand ) . You are right , no meaningful EPG . :-( Wyr |
| Posted on Wednesday, February 23, 2005 - 08:39 pm: |
2 things...as far as FTA's,the coolsat 4000 NOW has a WORKING EPG with the software released today..it will be public VERY soon Lastly is to stop the Dish ECM's ,use a checksum blocker...the latest are at www.romprotect.com |
Afroman Unregistered guest |
| Posted on Thursday, February 24, 2005 - 02:40 pm: |
my dish shut down today again. i have some kind of auto resetting dig. lock. all i have to do is unplug the receiver and plug back in and i am watching tv again. last time i would lock ever hour. got a fix from my programer and it was good. this morning i had to reset it again. i hope i dont have to get another fix today. |
| Posted on Thursday, March 03, 2005 - 08:00 pm: |
how do i tell if my receiver got hit. i only get channel 103 |
| Posted on Thursday, March 03, 2005 - 09:32 pm: |
Just READ!..the error messages and fixes are posted here above in this thread...error 153 = ECM,then U've been "hit"..and the fix is above that...unbelievable! |
New member Username: Pearls_7us
Post Number: 2 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 03:48 am: |
Guys, I dont understand why I am getting an error when i turn my satellite on. Its ERROR 005 and I dont know how to get rid of it. Above it says give it time...Does that mean give it time and keep it on or something else. I dont know how to get rid of this?? Is this a virus attack on my card or what?? Please let me know as I am very upset. Thanks. |
| Posted on Wednesday, March 09, 2005 - 08:30 am: |
No virus attack!...just do what it says, be patient its updating... |
Jon Sast Unregistered guest |
| Posted on Wednesday, March 09, 2005 - 06:51 pm: |
HI LK.. Try to get the fix for Pansat, do you have any? Thanks, Jon |
| Posted on Wednesday, March 09, 2005 - 07:28 pm: |
005 message...If using atmega..then U must reprogram Pansat fixs are everywhere...fix?...which one? |
| Posted on Wednesday, March 09, 2005 - 08:01 pm: |
GO to this link SATELLITE HELP and they will help you. if you have irc then you can get real time help as well. |
| Posted on Wednesday, March 09, 2005 - 08:53 pm: |
Pansat for Echo Star qq dishnet.. Thanks again..
Post Number: 3 Registered: Mar-05
| Posted on Thursday, March 10, 2005 - 05:48 am: |
But people i have already given it a day to update and it hasnt been able to update. It still says that ERROR 005 and still not gone. Should I just leave the satellite on and the TV off for a little longer. Please help me!!!!!  |
tommy chong Unregistered guest |
| Posted on Thursday, March 10, 2005 - 08:46 am: |
I just took a hit I'm seeing all sorts of s-h-i-t |
| Posted on Saturday, March 12, 2005 - 03:18 pm: |
Forum" means a chat area, message board, bulletin board (bbs), or e-mail function offered as part of any eCoustics.com Site. If you participate in any Forum within an eCoustics.com site, you MUST NOT: defame, abuse, harass or threaten others; make any bigoted, hateful or racially offensive statements; advocate illegal activity or discuss illegal activities with the intent to commit them; post or distribute any material that infringes and/or violates any right of a third party or any law; post or distribute any vulgar, obscene, discourteous or indecent language or images; advertise or sell to, or solicit others; use the Forum for commercial purposes of any kind; post or distribute any software or other materials which contain a virus or other harmful component; or post material or make statements that do not generally pertain to the designated topic or theme of any chat room or bulletin board.
New member Username: Iharris2
Post Number: 1 Registered: Mar-05
| Posted on Sunday, March 13, 2005 - 08:25 pm: |
Can anyone tell me how to do a factory reset on a dishnet7200 satellite receiver? |
| Posted on Monday, March 14, 2005 - 10:08 am: |
Unplug it for few hours.. |
ISblindScanOK? Unregistered guest |
| Posted on Monday, March 14, 2005 - 12:05 pm: |
LK...If i do so many blind scans on my FTA receiver is that OK? I have legal dishnet and i just bought a pansat2500a also. If i scan many times to get all the sats on my FTA can i get in trouble? Is someone from dishnet noticing these scans and identifying where it is taking place? I'm a newbie and i just started(two weeks ago) to learn about the FTA. You are helping everyone here and i hope you will answer these too. Thanks. |
| Posted on Monday, March 14, 2005 - 12:21 pm: |
FTA scans,programming etc is totally NOT connected to Dishnetwork subscription...FTA is a seperate receiver than your Dishnet receiver..and there is NO FTA or Dish "satellite" sniffers" like with cable TV vans and ways.. BTW...keep phone line unplugged into receiver,unless U are a complete Dish receiver legit subscriber.. |
| Posted on Monday, March 14, 2005 - 12:45 pm: |
THANK YOU VERY MUCH LK. I was really worried and was afraid to scan to get more channels. Yes i am a legit Dish subscriber but i also bought this new pansat2500a. While i am testing the pansat, i will unplug my Dish receiver and use the pansat instead. It took me 35 hours and so many tries to see the picture on it ;). I'm planning to get a spliter so i can use both at the same time. If i don't use the Dish receiver and only use my pansat, will i get in trouble? Really appreciate all your answers here! I'm sure so many other newbies feels the same ;) Thanks. |
| Posted on Monday, March 14, 2005 - 12:58 pm: |
Dish does NOT care if U do NOT use their receiver..they ONLY want your money every month |
VERY IMPORTANT NEWS Unregistered guest |
| Posted on Monday, March 14, 2005 - 06:22 pm: |
THE GUYS AT DISHNET NOW CAN VERY EASILLY CHANGE KEYS WHENEVER THEY WANT AND THEY KNOW ALL THAY CAN PlSS US OUT |
Pinochio Unregistered guest |
| Posted on Tuesday, March 15, 2005 - 02:48 am: |
Hey there, I have dishnetwork and am not happy with the amount of money being paid every month for what they offer. Can anyone suggest any websites that explain what to do for a first timer? The coroporate world is taking over everything! |
| Posted on Tuesday, March 15, 2005 - 08:36 am: |
Yes Call me at 9055617936 for more info about watching tv for free |
New member Username: Nub
| Posted on Tuesday, March 15, 2005 - 02:43 pm: |
please... how can i get the new codes for fta with dish software ...anyone |
| Posted on Tuesday, March 15, 2005 - 03:38 pm: |
Does the sat. 101 point to the same place as the 110 sat? What is the different between these two satellites? |
| Posted on Tuesday, March 15, 2005 - 10:51 pm: |
Hi LK, Thanks for ur valuable informations and advice. Do u have any idea about error 361. Thx Kaz |
| Posted on Wednesday, March 16, 2005 - 02:16 am: |
hey lk whats the best way to get started with this |
| Posted on Monday, March 21, 2005 - 01:44 pm: |
Hey Does anyone have any idea about what's going on with all those channels that are being blacked out by dishnet. They have already blacked out all Indian channels (611 to 619) and now 616, 620 & 621 are going to go this week. WHAT IS GOING ON? ANY FIXES? ANYONE PLEASE! |
| Posted on Thursday, March 24, 2005 - 12:18 am: |
Hi Immie, Just read your concern. I have the same problem and posted a message on March 15th but did not get any respond from anybody yet. As soon as you know anykind of fix , please post it. Best regards Kaz |
| Posted on Thursday, March 24, 2005 - 12:32 am: |
Welcome to Nagra2!...Bev/Bell will be all nagra2 within 4-6 weeks...Dish 3-6 months or sooner! |
New member Username: Van_goff
Post Number: 5 Registered: Mar-05
| Posted on Saturday, March 26, 2005 - 09:25 am: |
can anyone help with new keys? Thanks |
