Thread: Vcr will not record |
hidefgh Unregistered guest |
| Posted on Thursday, February 10, 2005 - 01:07 pm: |
help me!!!!!! i have a mitsubishi hs-413ur vcr. all of the sudden it will not record, either timed recording or instant recording. everything else is fine. does anyone know what the problem might be? is it worth repairing? thanks...gh |
Silver Member Username: Samijubal
Post Number: 607 Registered: Jul-04
| Posted on Thursday, February 10, 2005 - 05:47 pm: |
Is the record tab broken out of the tape you're trying to use? |
| Posted on Thursday, February 10, 2005 - 07:14 pm: |
no. the tape has the tabs intact. all the tapes i've tried have the tabs. any other ideas? thanks!! |
Post Number: 608 Registered: Jul-04
| Posted on Thursday, February 10, 2005 - 08:28 pm: |
What happens when you press record, anything? |
