Home > Message Board > Home Video > Satellite TV > Archive through February 20, 2005 > Hooking up satellite receiver
Author Thread: Hooking up satellite receiver
I am trying to hook up a satellite dish and receiver.I have an older home that is wired for cable TV. Can I hook the cable from the satellite dish into the cable that comes from the street where the existing cable enters the house? Can I then put the receiver at the cable outlet inside? Thanks for your help!
Username: Knee_grows_back
Post Number: 38
wow fruitcake....you making things difficult for yourself....just drill a hole thru the wall and put the sat cable in...leave that damn cable wire alone...what you hooking up? Starchoice..ROTF
LK
anon...yes U can...but depending upon how the cable is wired,don't know how many TV's are wired to the main cable outside which U need to hook up to a LNB on a satellite dish..probably just one..U will have to trace the wire and look for splitters etc..
Home > Message Board > Home Video > Satellite TV > Archive through February 20, 2005 > Hooking up satellite receiver [ « Previous ] [ Next » ]
