Thread: DVd red pro vs burning DVD on computer? |
Saruman Unregistered guest |
| Posted on Tuesday, January 25, 2005 - 06:52 pm: |
It seems like the people who have posted on here about DVD red pro just want to sell it. I would love to get some first hand accounts of its working and not working. SOme say that burning is better but if you do that on the computer..my friend told me that you cannot keep some of the commentaries and special features..is this true? I like the DVD recorder because I can tape the commentaries and such. Also...why do some Criterion Collection DVD's have copy protection and some randomly do not? Is there a list which has the ones that are? |
Silver Member Username: Samijubal
Post Number: 585 Registered: Jul-04
| Posted on Saturday, January 29, 2005 - 05:23 pm: |
The PC is the way to go. You can fit whatever you want, sometimes it has to compress is all. If done right the PC will make a far better copy without having to buy a stabilizer. You can always use 2 discs if you don't want to compress or if the compression is too high. Use DVD Shrink and DVD Decrypter. |
New member Username: Ilo_recorder
Post Number: 1 Registered: Feb-05
| Posted on Tuesday, February 08, 2005 - 01:03 pm: |
I just bought the DVD Red Pro and have not had luck yet. I tried to copy one VHS and at first it worked, but then I got the same copy protection error as I did w/o it. It stopped after only a few minutes. I am trying to work with tech support via e-mail. I got one response back, but that hasn't helped me yet. I have another message into them and hope they can tell me how to fix it. I am also upset that VHS tape is messed up though too. I asked if that was normal and didn't get an answer to that yet. Good luck. |
| Posted on Thursday, February 10, 2005 - 10:33 am: |
I just bought the DVD Red PRO and it works great! I haven't had any problems recording DVD to DVD. I would definitly recommend it to anyone. |
| Posted on Thursday, February 10, 2005 - 10:48 am: |
Stanjr, What type of units are you transferring from and to? I am having many problems. Most of my VHS tapes still say "copy protected". I've had volume problems, color problems, and one VHS that actually has snow, volume problems for the first few minutes that I tried to transfer. I have a Sylvania DVD/VHS player combo that I am transferring from going to an Ilo DVD Recorder. Thanks for the help! |
| Posted on Thursday, February 10, 2005 - 05:31 pm: |
I have a Zenith DVC 2200 DVD player...transferring to a Panasonic DMR-E55. I haven't tried transferring VHS tapes with protection, yet. If you continue to have problems you should consider joining netflix, blockbuster, etc. I'm sure they will have any movies you are trying to copy from your VHS tapes. |
| Posted on Friday, February 11, 2005 - 08:14 am: |
Thank you for your input. I think I am going to either try just a DVD player or a VHS player and not a combo player with the Ilo recorder. If that doesn't work, then I'll probably try a different recorder. The movies you are transferring, are they newer ones or older ones? Just curious. Just thought that maybe the new videos are more advanced with copy protection than the DVD Red Pro. Thanks for your help. |
| Posted on Friday, February 11, 2005 - 11:38 am: |
I don't nessesarily care for combo units. I'm transferring new releases,older videos,home videos,etc. I haven't had any problems. Again, I would recommend a video club. Hope you can find a solution to your problem. Good luck! |
puzzled Unregistered guest |
| Posted on Friday, March 25, 2005 - 06:02 am: |
stanjr, im thinking of buying a DVD pro red, they sound pretty good but I'm just wonderng it the Dvds you copied are protected? Have you tried disconnecting the DVD Red Pro & then recording, Thanks for any help u can provide. (Ive got a JVC DR-M10) |
Post Number: 729 Registered: Jul-04
| Posted on Friday, March 25, 2005 - 01:04 pm: |
Almost all DVDs are protected. The only ones that aren't are some of the low budget B grade movies. |
| Posted on Tuesday, March 29, 2005 - 12:37 pm: |
If It won't copy protected movies why is it needed and why spend you dollars on it? Looks to me like it causes many other problems. |
Post Number: 762 Registered: Jul-04
| Posted on Tuesday, March 29, 2005 - 02:22 pm: |
If you want to do DVDs, get a burner for the PC, they are cheaper, faster and alot better quality. |
| Posted on Wednesday, March 30, 2005 - 11:49 pm: |
Can anyone help? I have a lvw 5006 and am trying to use "Red Pro" to transfer VHS (protected) to DVDs. Everything is great, picture, audio, etc. but on play back the movie stops every few seconds and sometimes starts up again on its own and sometimes the "play" button must be pushed. Has anyone had this problem and if so did you find a solution??? |
Post Number: 770 Registered: Jul-04
| Posted on Thursday, March 31, 2005 - 02:41 pm: |
Sounds like cheap media, try better discs. |
| Posted on Friday, April 01, 2005 - 01:39 am: |
You may be right. I get what I paid for. I'll use the same equiptment only with name brand discs and see what happens. Thanks.... |
jon_irl Unregistered guest |
| Posted on Monday, April 11, 2005 - 10:23 am: |
Has anyone used the Sonel Marco master pro to remove macrovision when copying from dvd to dvd?? is there any picture/sound degradation? Thanks......... |
Post Number: 826 Registered: Jul-04
| Posted on Monday, April 11, 2005 - 04:46 pm: |
If using a standalone there will definitely be picture degradation no matter what you do. A PC is far better and faster. Take that money and buy a burner. |
anonymouslalala Unregistered guest |
| Posted on Saturday, May 28, 2005 - 08:04 pm: |
If i were to burn DVDs from blockbuster rentals, is there any way that they can figure out that i've done that, and like cancel my membership or something? |
New member Username: Dokkenman
Post Number: 1 Registered: May-05
| Posted on Tuesday, May 31, 2005 - 12:18 pm: |
I have the dvd red pro and the image is fine along with the sound when I record the movies. The problem is when I try to play the copied dvd in another dvd the image freezes for a sec and then keeps going and then it does it again. Is there anyone that can tell me why this is happening ???? Thank you. |
Post Number: 2 Registered: May-05
| Posted on Tuesday, May 31, 2005 - 12:36 pm: |
What DVD+R or +RW discs brands do you recommend ???? |
| Posted on Tuesday, July 05, 2005 - 05:31 pm: |
I just purchased the latest LG DVD recorder RH7624w with 250 hdd and would like to know if the DVD red or sima ct is going to work best .PLease help |
