Home > Message Board > Home Video > Rear Projection TVs > Archive through February 25, 2005 > Mits. WD-62525 AVR control
Author Thread: Mits. WD-62525 AVR control
Username: Sthughes
Euless, TX
United States
Does anyone know how the AVR control on the WD-62525 is supposed to work? I am assuming if you set it up properly with a supported receiver then switching devices should also switch the device on the AVR and that the volume control should control the AVR not the tv, but I can't seem to make that happen. Any help would be appreciated.
remotenoworky
There are a lot of incompatabilities among the brands. Sometimes the codes work and sometimes they don't. What I hate is that one device has 3 digit codes and another has 4 digit codes. The remote I want to use only programs 3 digit codes.
Home > Message Board > Home Video > Rear Projection TVs > Archive through February 25, 2005 > Mits. WD-62525 AVR control [ « Previous ] [ Next » ]
