Thread: Audio not recording |
New member Username: Jumpbid
Post Number: 1 Registered: Jan-05
| Posted on Thursday, January 20, 2005 - 10:40 am: |
I have been making second copies of instructional videos between a vcr and tv/vcr combo. All of a sudden the duplicate tape has no sound. The only adjustments I've made was to change the speed to try to put more copies on the same tape. Could that be the problem? Thanks. |
New member Username: Goliath
Post Number: 1 Registered: Mar-05
| Posted on Sunday, March 27, 2005 - 03:18 pm: |
hi, Just wanted to know if the Sima Ct-2 or Sima CT-1 will allow me to copy my old vhs movies right on to DVD. I have a SONY DVD recorder. Thanks |
Silver Member Username: Samijubal
Post Number: 743 Registered: Jul-04
| Posted on Sunday, March 27, 2005 - 03:46 pm: |
You only need it if they are prerecorded tapes. |
Post Number: 2 Registered: Mar-05
| Posted on Sunday, March 27, 2005 - 04:12 pm: |
thanks. Is there a big difference between the CT-1 and the CT-2? |
Post Number: 745 Registered: Jul-04
| Posted on Sunday, March 27, 2005 - 04:45 pm: |
I haven't used them, I think one has picture adjustments and the other doesn't. |
Silver Member Username: Dmwiley
Post Number: 287 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 06:47 pm: |
Check Simacorp.com for specs/comparisons. Iris, speed of recording should not cut out your audio. |
