Home > Message Board > Home Video > VCR > Recording TV Programs, onto VCR?? ple...
Author Thread: Recording TV Programs, onto VCR?? please help
revlon889
Hey,
What I want to do, is take a basic cable television program. Which is on Fox (channel 12) and use my VCR (JVC Pro-Cision 19 HEAD) to record it onto a blank tape. I have my VCR connected so I can play regular movies. I have tried recording using the both connectors, the cable connecter (the one with the single pin sticking out that screws into the wall) and the I/O Connecters (red, white, yellow) If anyone could give me a step by step process on what to do, using either connectors that would be great. Thanks for feedback. Bye
Username: Samijubal
Post Number: 574
Connect the coax cable, then go into the setup menus, select cable for input, then autoprogram the channels.
Username: Greg71586
Kalamazoo, Michigan
United States
I'd like to know what a coax cable is, what setup menu you're talking about, and what is autoprogram?
Username: Samijubal
Post Number: 580
Coax is the round cable that the cable company uses. If you press the menu button there will be a setup menu where you can select cable or antenna. There should be a program channels menu there too.
an9el_l3a3ie
i am trying to record a program from dish network onto a samsung DVD/VCR. I've tried many things if someone could help me out that would be awsome!
Username: Samijubal
Post Number: 683
Connect RCA jacks from the satellite to the VCR and set the VCR to line. There should be an input button on the remote to set the VCR to line.
Username: Zedsimon
If there's no button for line input, use the VCR tuner's up and down buttons to tune to channel L-1.
an9el_l3a3ie
thanks guys!
an9el_l3a3ie
thanks guys!
Username: Crazygill2299
Hi guys!
Okay this is a tough one. I have a JVC tv and a VCR( QUASAR company). I have no cable TV just the basic 22 channels. I want to record a TV program grom abc channel 7. I dont know how to do it. Im really not good at these things.
So if anyone could please write the step- by- step instructions to record a TV program onto a videocassette; I woul love it and be very grateful.
Thanks in advance 4 your help.
Please reply SOON!
Username: Samijubal
Post Number: 728
Connect the antenna to the in on the VCR. Then go into the setup menus on the VCR and set on antenna, then use autoprogram to set the channels. When you're ready to record set it on channel 7 and set the record speed.
Brian05
Is it possible to connect the VCR to antenna (RF input) and take the output from the RCA(red, yellow and white) pins. My TV has only the RCA input working. Basically will the VCR take RF as input and give RCA output?
Username: Videoguy
Post Number: 13
Yes that will work! basically what you will be doing is using the VCR as an external tuner, just plug the RCA output on your VCR into the RCA input on your TV and use the VCR to change channels. I do it all the time to watch cable on my LCD video projector which only accepts RCA inputs.
Hardy
I am tring to play back my video from my DV camcorder. I have followed the instructions for connecting the camcorder to the VCR listed above. I can hear the audio, but I don't see the video. I can kinda make out some images, but I mostly see a blue scrambled screen. What should I do?
Mikey Ray
Hello, I have digital Warner cable and I want to watch one show on the cable box while recording a different show on the vcr. Or just record shows on the vcr while tv and cable box are off. How do I hook that up please? I have tried cable to vcr to box to tv and I have tried cable to box to vcr to tv. Neither allows the vcr to use it's tuner. All I get is blue screens unless I tune the vcr to channel 3.
Username: Samijubal
Post Number: 1584
You can only record analog channels while watching digital. Split the incoming cable to the box and the VCR, that will allow the VCR to record analog channels.
>connecting the camcorder to the VCR listed >above. I can hear the audio, but I don't see the >video. I can kinda make out some images, but I >mostly see a blue scrambled screen. What should >I do?
Hardy, your problem is macrovision protection.
For more details and to get answer on how to fix it you can use the following information:
http://www.xdimax.com/common/default.html or simply
www.xdimax.com
Username: Samijubal
Post Number: 1587
It's not Macrovision on a camcorder.
Username: Videoguy
Post Number: 121
Hardy:
Could be dirty/bad heads on the DV CAM or a bad tape. Does it play back scrabbled on the camera’s LCD also? If not then there is probably a bad connection somewhere between the camera and VCR. Try a different tape, try wiggling the cables, if picture gets better or worse then it’s a bad connection. Does the VCR exhibit this symptom on all inputs or just with the DV CAM?
Hi
I am trying to record cable program in my Mitsubishi VCR. I'll try every thing but it's not working . I have new SHARP TV.But i use to record TV program in my old TV with same VCR.
Please help me.
Thanks
Username: Illuminator
Post Number: 1798
You have to hook up your cable connection to the VCR's built in tuner. Then use the VCR to select the channel you want and hit record.
Shez
Hi, Please Help!!! i am trying to record from my camcorder onto a blank tape in my video recorder. when i plug all the cables etc. into my tv or video rec. it veiws fine. I also have no problems watching videos on the tv.
tried tuning it in and everything but when i press record it just plays back showing a blue screen with no sound. Where am I going wrong???
Username: Samijubal
Post Number: 1727
Connect to the VCR with RCA cables and set the VCR to line.
Shez
Thank you so much for your help. Hopfully my friend will know what RCA cables are & how to set it to line. I'll try it and let you know the results. Thanks again.
andjohnso
What is this "set vcr to line" or "L-1"? I'm trying to use my JVC(HR277MS)VCR as an external tuner. Lost my original remote and got a universal. Hooked up the coax RF(in), but can't get a menue to tune in or select input. I do see, however this L-1 on the screen. How do I tune in?
Username: Samijubal
Post Number: 1742
You need to get into the menus. You could try unplugging it long enough to reset, then it might autoprogram the channels.
I have a JVC Pro-Cision 19 HEAD VCR (Model Number HR-VP672U). I have lost my remote to this device. I am trying to change the Tape Speed from SP to EP. I have not been able to figure out how to do this without the remote that was shipped with the VCR. As a result I can not tape over 2 hours.
I have cofigured ny Direct TV remote to control the VCR, but I am still unable to switvh the tape speed. Has anyone encountered this problem with this VCR or can help me change the Tape Speed.
Username: Samijubal
Post Number: 1754
If it has a menu button on the VCR, and you can't change it in the menus, set a short timer in EP, then it may change to EP after timer recording.
Confused*__*Recorder
I'm having troblue recording a tv program, from annetena, without a remote. The vcr is old, but new hookup. do i need to program anything in the menu? ive tried by just setting the vcr on the desired channel and hitting record, which has no response.
krimsky
I have a sypmphonic VCR/DVD combo, and then your basic cable. I want to record something off the TV but I've tried everything. Theres no where on my remotes that let me set it up as cable/antenna or anything. If you could help that would be great!
Username: Samijubal
Post Number: 1831
If there isn't an antenna/cable select, it will do it automatically when you autoprogram the channels, which is what you need to do.
hi i wanted to know if there was any way that i could record a dvd video onto a vhs tape i have both a vcr and a dvd please help.!
Hi. I have a Sharp VCR and I am trying to record a show while I'm watching another show..is this possible? If so, how do I do it? Thanks!
Hi, I am trying to record a program from dish network onto a Zenith DVD Player/VCR Cassette Rcorder.......I have tried many things....Its not working....Please help
Username: Samijubal
Post Number: 2207
Connect the sat to the combo with RCAs and set the VCR on line.
ateensg8
hi. i'm trying to record a tv show onto a casette. and i dont know how... am i supposed to plug something in to my vcr? plz help!!!
nglfranklin
Hi I have a D-VR35SB DVD recorder and VCR combi. I am able to record analogue channels but none of the Digital channels from the T.V(we have freeview). What am I doing wrong?
nglfranklin
nglfranklin
Help. I've had the satelite guys out twice and they can't seem to fix the problem. I use to have cable and now I have satelite. My VCR I am assured is connected properly and acts like it's recording but the tape is still blank when done. I was told to put it on three to record and I do but still nothing. The vcr is six years old and does play tapes but won't record now. It did record when I had cable. The menu setup only allows for tv, cable tv, or axl but not satelite. Can you not time tape with satelite? If not I'm cancelling since I'll never get to see anything since I work evenings. Thanks for any help. Liz
Can anyone please just give me directions how to record a TV show on cable, onto a blank VCR tape?
I did it before-but can't remember how to set it up - channels to record on -different than what the VCR is set up to record from! I am very confused cant remember what I did last time I recorded a show. I dont have the original owners manual to help. This machine is a Sharp VC-1106
Username: Samijubal
Post Number: 2344
Autoprogram the channels, set the antenna/cable to cable first. Put it on the channel you want, select the tape speed and press record.
Can someone out there please help me? I have a Panasonic Omnivision VCR that has me pulling my hair out. I have the basic connections. Cable box to "In From Antenna" on the VCR. Then I have a cable running from "Out to TV" on the VCR, to the TV Input. My TV is an RCA. The problem is that the VCR will not play any tapes that I record from Cable. The VCR seems to have trouble "tracking" the recording. It will play for a few seconds then then the tape starts "skipping". Then there is a blank (blue) screen. The display says "SP" for speed, but I record all my tapes on "SLP" speed. Oh yeah, when I attempt to play my favorite "pre-recorded" tape, there is no problem. What gives???
Username: Samijubal
Post Number: 2361
It either needs cleaned, head cleaning tapes don't work, it's out of alignment, not usually a problem with Panasonic, it has a bad pinch roller, or a tension band problem.
mally
I have a 4-head Sharp VCR. All I want to do is record a tv show that's on a cable channel to a VHS tape. I've been trying forever, but it just won't work! PLEASE HELP! I have about 20 minutes before the show comes on!
mally
A few days ago I purchased a Sony 4 head VCR so that my wife could program her favorite Soap Operas and watch them at night. I think I got burned! When I started reading the manual, it mentioned that this machine had a 1 month, 8 event recording timer. Does this mean my wife only has the option of programming 8 events per month??? She likes to program every morning before she goes to work. When I did a search on the website of my favorite electronics outlet, it seems that almost all of the vcr's listed had similar limitations. Whatever happenned to the days when you could program a vcr with no such limitations. Where have I been?
Reg.
Username: Samijubal
Post Number: 2398
Those 8 programs can be set to record every day. If she records the same thing every day, just set it for Monday-Friday, or daily if they are on every day.
Username: Elbowlean
Milwaukee, WI
I have a JVC combination video recorder and DVD player and a JVC TV. I can only record a TV program on one channel. I work evenings and would like to record programs that are at different times and different channels. Is it possible to record numerous program on different stations in the same evening?
Username: Mattamus6969
Leicester
Uk
hi just got a digital reciever and cant recive a good picture quilty through my vcr. how do i set it all up? any help would be great. thanks
email mattamus6969@hotmail.com
Username: Tech_123
I have a sony VCR, and i want to record a TV show onto it. But i suspect there is something wrong with the audio... Something in the back connects it to the antenna receiver, and the other connects to the TV. When I try to record something, I need to set it to either L1, L2 or PR1, I haven't figured out which one yet. But whenever I finally get the antenna recorded on the video tape, it has no sound. When I switch the input on the tv and go on the video one and try to open the menu, it doesnt work.. Is there any way you can help me hook it up properly/fix it/record the show onto the tape?? thank you!
Username: Samijubal
Post Number: 2609
Exactly what are you trying to record from and how is everything connected?
Username: Tech_123
It's alright, the program's passed, and I still have no idea... I have no idea how things are connected, my friend did it for me, and instead of L2, i chose L1, and didn't record... I'm not sure I ca explai how it's connected.. Thank you anyway!! :-)
Username: Dakota
I have Direct TV, Toshiba 46 in TV, Sony DVD/VCR recorder, Sony home theater and CD player.
Every thing plays correctly EXCEPT I can not record anything. Why what is wrong Help please
Username: Lesliem
St. Petersburg, FL
I have a Samsung 32" LCD and a Samsung DVD/VCR combo i hooked it up through component the DVD works fine bt the VCR doesn't work at all. Help
Username: Samijubal
Post Number: 2768
Components only work for DVD. The VCR has seperate composite outputs.
Username: Silkysmooth
I have a Panisonic palmcorder VHS-C, and I need to record from it to VHS. I have 2 VCRs and a TV. How do I hook it all up and record to a VHS?
I tried hooking the camcorder to the VCR IN, and then hooking the VCR from the OUT to the In of the Tv and I only got a shadow of what I wanted to record and no Audio. Can you help?
Username: Lesliem
St. Petersburg, FL
David thanks. I used an RCA cable for the VCR and now it works but i can't record and have no surround sound. I need a receiver which i'm going to get today hopefully that'll help. Thanks
Username: Lemmoth
New York, NY
I have an old TV with just a coax input, no RCA inputs. A mono VCR which we used to use as a tuner. Just added the digital cable box from Time Warner (to get HBO, Showtime etc). Own an RF modulator and a DVD Player equipped with S-Video. Want to be able to: 1.)Tape any channel when not home (TV off)2.) Tape any channel while watching another. How should I hook it up. Thanks.
Username: Samijubal
Post Number: 2785
You can't record a digital channel and watch a digital channel at the same time, unless the box has dual tuners.
Username: Lemmoth
New York, NY
Ok. So what about recording a World Cup game on ESPN in the morning while I'm at work. What is the direction of the appropriate wiring. Coax to RF to VCR etc. I can't seem to make it work.
Thanks
Username: Samijubal
Post Number: 2786
RCA cables are better for picture quality. If you want to use coax, out of the box to the in on the VCR, out of the VCR to the modulator. The VCR has to be on whatever channel the box outputs on to record, I'd guess channel 3.
Username: Coolio123456
If i want to use RCA cables, what is teh process of recording cable tv with my vcr.
Username: Samijubal
Post Number: 2805
Connect RCAs from the box to the in on the VCR and set the VCR to line.
Username: A_hiser
Please someone help me. I am an old woman and need help. I recently switched to satellite. Now, when I try to tape a show on my vcr it acts like it is taping but it is nothing but snow when I play it back. It used to tape when I had cable. How do I play it back? Maybe thats what I am doing wrong? It plays the old tapes that I taped from cable. Please help me. Thanlks
Username: Lovelygirl
hi can someone please tell how to record dvd to vcr tape and the VCR tape is a used one so i dont how record it. can you please explain to me step by step thanks
Username: Beargo
I Would like to thank John for the help with recording a tv program to my vcr. Everything worked out fine,
Thanks to John's instructions...Dave
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > VCR > Recording TV Programs, onto VCR?? ple... [ « Previous ] [ Next » ]
