Thread: Bad channel or scrammbled channel fortec star |
New member Username: Meat
Post Number: 1 Registered: Jan-05
| Posted on Sunday, January 16, 2005 - 06:20 am: |
can't seem to get any channels on my fortec. First the screen said downloading info then input data would come up. I went to dsscommuntiy and downloaded the new key code deal and know it says key codes changed. Now for some reason it says bad channel or scrammbled channel. I thought the software download was supposed to unscrammble the channels.Can any one help please. |
largo key Unregistered guest |
| Posted on Sunday, January 16, 2005 - 09:47 am: |
Need to scan the channels or download a channel list...go back to dsscommunity and download a channel list and do some more reading.Changing the parity keys is NOT scanning the channels or adding a channel list!...read both the pansat and fortec areas,since they're basically the same.. |
| Posted on Friday, January 28, 2005 - 07:12 am: |
Trying to flash ver60 i keep getting a file type dismatch error. How do i resolve this problem/ |
| Posted on Friday, January 28, 2005 - 07:52 am: |
COME WITH ME IF YOU WANT TO WATCH. |
| Posted on Saturday, January 29, 2005 - 12:19 am: |
Hi, I am about to buy a FTA unit...here is a site that has the newest model avalable. I am presently testing with a DVB card (Nexus-s) and its been solid with Dish and Bev. THe Max 2000....for 199 CAD...that is a good price from what I have seen. http://www.dvbmaster.com I hope this helps anyone who is looking for a FTA unit. And no there is no P4/5 hack.... Regards, Bennyguy |
