Home > Message Board > Home Video > Satellite TV > Archive through January 21, 2005 > Need Help
Author Thread: Need Help
Username: Sortarican
JUST GOT PANSAT 2500A WORKING FOR 110&119. NOT GETTING NO EPG. COMES UP BLANK. THANX FOR ANY HELP. BEEN LOOKING AROUND 4 A WHILE AND CANT LOCATE ANY INFO OR DOWNLOADS FOR IT.ALL CHANNELS COMING IN. JUST NEED EPG.
largo key
No program guides with any FTA
largo key
Sorry to say that the EPG does not work on 110 or 119 but it does work on 91 clamer500. Usually when you download an up to date channel list you do not have to do a sat scan. It should appear on your tv just as it does in your Gtools. If you are looking to find your locals you may have to do a particular tp scan to get them though
Home > Message Board > Home Video > Satellite TV > Archive through January 21, 2005 > Need Help [ « Previous ] [ Next » ]
