Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > PC on TV
Author Thread: PC on TV
Username: 1time
I'm going to be buying a CRT projection HD ready TV very soon. My PC has a 2nd DVI output. The manual for the TV says that the digital input is not meant for use with PCs. But, If I make sure the PC video output is set to match the TV's resolution and refresh rate, would there be any problem using the PC through the TV? I dont't want to damage the TV obviously. But I would think if the the gets a signal it can understand from the PC there would be no problem. I don't need to use the PC on the TV, but it would just be a nice bonus...Any input is appreciated.
Username: 1time
Is there some kind of trick to getting any answers around here? I've asked a few questions that I think are reasonable and have never gotten a reply.
Peas
Don't do it. It is as dangersous as removing the tag from your mattress. Tread these waters at your own risk.
Peas
Username: 1time
What about VGA to component video converters. Do they pose the same risk? Is the picture quality good from them?
Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > PC on TV [ « Previous ] [ Next » ]
