Thread: Multiple reciever in house. |
| Posted on Tuesday, January 11, 2005 - 01:13 pm: |
Hey guys - I wondering if you guys know how to install multiple recievers in a house w/o more than one dish? Is it possible? Would you have to watch the same thing on each tv? I wondered if there was some type of splitter? I have 3 rooms and want FTA in each. Thanks in advance |
largo key Unregistered guest |
| Posted on Tuesday, January 11, 2005 - 08:22 pm: |
its NOT how many dishes (but the more the better)...its how many LNB's are on each dish...and what kind of dish...then U use a multiplitter.. U are giving little to no info..its like U sayong "I have a vehicle,can I tow an airplane"...not very specific! If U want different channels in each 3 rooms,then U need 3 different FTA's |
| Posted on Tuesday, January 11, 2005 - 08:33 pm: |
A dish pro lnb has a built in diseqc switch which receives 110 and 119 via one cable which can be connected directly from the lnb to the receiver without an additional switch. It has two outputs which can allow it to accept two receivers from the same lnb. It would require the use of two individual cables,one for each receiver. A dish pro does have to have a special channel list though. |
| Posted on Wednesday, January 12, 2005 - 10:06 am: |
Hey Largo sorry for not enough info. I have a dish 500 which will point to 110, 119 with dual lnb. Using pansat 2500a receivers in 3 rooms. Thanks in advance |
