Thread: Pioneer DV-533K play VCDs but not DVD |
Sung Lok Unregistered guest |
| Posted on Sunday, February 08, 2004 - 07:08 am: |
My Pioneer DV-533K has problem to play any DVD, DVD-R, DVD+R, DVD-RW, Region 3,4,1 & ALL it used to play smoothly. When a DVD (any format or media) is inserted, it spins for around 20 seconds and will either stop or reject the disk. I've got this from Sydney Australia, the lable behind is zone 4 which is Australia or South Amercia. I'm not sure if it has been patch or not? (i'm just user) Did anyone has this problem with Pioneer ? or the DVD side is completely dead. There was no drama from the last DVD-R I played, now it can play VCD & CD only. Thanks for any advices in advance.
| Posted on Sunday, October 17, 2004 - 02:45 am: |
i also tried playing dvd-r which i burned but it doesn't play on my pioneer 533K.. |
