Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > Computer to HDTV...... please help.....
Author Thread: Computer to HDTV...... please help.......
PB
im using Asus Extreme AX600XT/HTVD and im trying to connect my HDTV adaptor (YPbPr) to my tv...... the problem im having is the icons are to big and it doesnt fit on my screen..... its stuck at 720x480 30hz..... is there anyway to change it? i tried everything and im using all the newest drivers....
thanks
xvxvxvx
You need a program called Powerstrip, it will allow you to adjust the output resolution to properly display on your HDTV.
xvxvxvx
I'm having trouble getting a good quality from my HTPC on my HDTV picture I hope somone can help.
I have an Advent 27" HTPC that says it can accept 1080i resolutions.
I have an ATI Radeon 9600 Video Card with the latest Drivers and the latest Powerstrip.
I'm using ATI HDTV (Component) dongle from teh dvi port on the video card.
I've tried a lot of settings (including some custom settings) and everything is pretty bad. Does anyone know the magic combo?
Thanks!
adam22 here Thanks...I'm already usig powerstip, and I've monkeyed around with a bunck of settings, but I feel like I'm wasting my time without some guidance as to which settings work on this TV. Let me know if you have any ideas.
Thanks!
Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > Computer to HDTV...... please help..... [ « Previous ] [ Next » ]
