Thread: Can people post their settings for Samsung DLP's? |
New member Username: Designknob
Post Number: 2 Registered: Dec-04
| Posted on Sunday, January 02, 2005 - 02:12 am: |
It would be most appreciated. I just got a 4674W and everything seems to be a bit too red. I'd like to see what others have found to be "optimal" |
Still Learning Unregistered guest |
| Posted on Sunday, January 02, 2005 - 10:34 am: |
Pull up the picture menu and play with it. I backed my color level down to 45, moved my tint a little toward green. My brightness is higher in the daytime, like 55, and lower at night, like 45, if I remember to change it. You may not have such drastic light level changes in your room. My contrast is at 90. Optimal is what looks good to you, though. |
| Posted on Sunday, January 02, 2005 - 12:28 pm: |
Mike M: If you have any of the Stars Wars dvds there is a THX picture setup utility on those. I used it on my 4674 and it looks great |
