Thread: Using S-video With Panasonic PT60-LC13 |
New member Username: Robe
Post Number: 2 Registered: Dec-04
| Posted on Friday, December 31, 2004 - 02:21 pm: |
Hi, Does anyone know if you need to enable s-video for the panasonic PT60-LC13 ? When I hook my HT system into the S-Video for any of the input slots I get no video. If I use a standard Video cable it works. Do I have to do something to make S-Video work ? Thanks Rob |
New member Username: Bangbang023
Brooklyn,
NY
United State...
Post Number: 1 Registered: Dec-04
| Posted on Friday, December 31, 2004 - 09:51 pm: |
You may want to try standard trouble shooting and see if another device, hooked up via s-video, will work. If it does, you know the HT system is to blame. If it doesn't, then you may have a fault port on your set. I really doubt you would have to "enable" such a connection on the set itself. |
