Thread: Rear Projection Between 2000-2500 |
New member Username: Jssilva
Post Number: 1 Registered: Dec-04
| Posted on Monday, December 27, 2004 - 11:57 pm: |
Hello, I have been trying to sift through mountains of information all over this message board as well as other sources on the internet. There is an overwhelming amount of information and I am finding it hard to make a decision. I plan on spending around 2500ish (excluding the warranty plans). Right now I am looking at: Sony 42" Grand WEGA™ HDTV (KDF-42WE655) Samsung 46" DLP™ HDTV Monitor (HL-P4663W) Both of these sets are available on CC's web site for around 2299. The question I have is would either of these be a wise decision? I would like to hear some responses on which set people think I should go with (or maybe neither, suggesting another television in this price range). Thank you in advance for all your help and sorry if this information was already available, I have been digging for hours with so much information difficult to compile together. Thanks again, Josh |
| Posted on Tuesday, December 28, 2004 - 02:16 am: |
Note for around $2500 today (projector plus screen), with a new generation 720p true HI DEF FRONT projector LCD you can buy what would have cost you 10 to 15k just 3 yrs ago However its really better for semi-dedicated theater rooms where you have some light control, don't run the TV continously hi-time, and have it protected from kids as these projectors have to be handled carefully Best of the new generation models I believe is the just introduced Panasonic PT AE700U with a very unusual 2.0 lens - permiting high flexibily for shelf placement Sanyo has the Z3 and Infocus the 5000 model, not bad either, with Sony also having a more expensive, but not necessarily better, new model Once you see one NFL game or one mega-movie in true hi def on HBO etc on one of these with a 92 inch 16:9 picture - you would never even consider a smaller set. They will simply blow away any normal HI DEF LCD, plasma or CRT away Now if you actually for practical reasons need a rear projector for sure, the Sony 42 is a good rear projection LCD for the price. I believe the bulb issues have been resolved on it. DLP unfortunately has an unknown factor - and that is whether audience members get headaches from the spinning color wheel, innate to single chip DLP's |
Post Number: 2 Registered: Dec-04
| Posted on Tuesday, December 28, 2004 - 10:30 am: |
Thanks for the input. Any other suggestions from people with pros or cons for either set? |
Post Number: 3 Registered: Dec-04
| Posted on Tuesday, December 28, 2004 - 10:32 am: |
I suppose it should be good to mention I plan to play a good amount of both HDTV, video games, and DVD movies on the set that I end up with. I do not know if the video game playing adds any other aspects to the decision that I should be worried about. Thanks again. |
