Thread: MITS WD 62825 TILT PROBLEM |
| Posted on Saturday, December 25, 2004 - 04:57 pm: |
My set has a tilt problem on the right side, it is higher then the left and the guide looks crooked. I have had my set over a month. Any suggestions on what I should do. I think the Mits warranty is 1 yr. |
New member Username: Cwh359
Cookstown,
Nj
Usa
Post Number: 2 Registered: Dec-04
| Posted on Saturday, December 25, 2004 - 08:43 pm: |
sonja if the TV is under warrenty still call a dealer the problem is that the convrgernt is off and need to be realigned that has to be done from the inside of the tv |
Unregistered guest |
| Posted on Saturday, January 08, 2005 - 09:14 pm: |
My 5 year old 55" Mits, has a curved line on the top and the bottom (Concaved). I believe that it is a problem with the T&B pincushion adjustment, but I don't know where that adjustment is. Can anyone help? |
Bronze Member Username: Hidefkindaguy
Phoenixville,
PA
Post Number: 11 Registered: Nov-04
| Posted on Monday, January 10, 2005 - 10:56 am: |
I too experienced a slight tilt with my 62825. I had an authorized Mits service technician perform the tilt adjustments under warranty. The picture is now perfect. |
