Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > Hook Game Cube Up To HDTV Cable System
Author Thread: Hook Game Cube Up To HDTV Cable System
UnTechnickle
I'm trying to hook up my game cube to a new HDTV wide screen TV/cable set up. I'm just used to putting the thing on Line and then hooking up the wires, now I have NO idea of where to even begin. I'm just trying to play a little bit of Madden but this is driving me plan MAD!
stendall
Hook the red, white and yellow cables of game cube into a composite input of your tv which is usually video #1 input. Then on your tv remote hit the input button that corresponds to the input used and you can Madden away.
Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > Hook Game Cube Up To HDTV Cable System [ « Previous ] [ Next » ]
