Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > Mitsubishi new 52'' cable problems...
Author Thread: Mitsubishi new 52'' cable problems
Username: Zeppelin89
A white screen keeps popping up every 5 minutes saying there is an error connecting with the cable. Then you can press home on the remote and it goes right back to the picture. It then says something about a CableCard or memorizing the stations. Memorizing the stations fixes it for about 15 minutes but then it just starts over. Is there any easy solution to this problem?
Any input would be great. Thanks
Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > Mitsubishi new 52'' cable problems... [ « Previous ] [ Next » ]
