Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > PC (DVI or S-Vid) to HDTV ?
Author Thread: PC (DVI or S-Vid) to HDTV ?
Have ATI 9800 Pro vid card (with S-vid or DVI out).
Want to view output on Sony KV-32HS420 HDTV (with Component, S-vid, and HDMI input).
What cable/converter would provide best resolution on the HDTV?
I've heard s-vid to s-vid will look horrible, as will a DVI to HDMI converter.
Have seen a DVI to VGA converter.
What will VGA look like in HD?
Have also seen ATI's DVI to Component converter.
But they say you may get some over-scanning (cropping) if your TV doesn't have 720p mode.
---- I think my Sony does, not sure ---
So, anyone done this before successfully?
Thanks,
cra2 "at" mindspring "dot" com
Home > Message Board > Home Video > TV Basics > Archive through January 19, 2005 > PC (DVI or S-Vid) to HDTV ? [ « Previous ] [ Next » ]
