Thread: Did I make a decision I'm going to regret? |
New member Username: Gecko
Post Number: 4 Registered: 01-2004
| Posted on Monday, February 02, 2004 - 06:08 pm: |
About 2 weeks ago I got a Sony 36" WEGA flat tube TV (KV-36FS100)for a wedding present. I decided to go for the bigger size for the budget ($1000) instead of an HD TV. Is this something I'm going to regret in the near future? Pete |
Post Number: 7 Registered: 01-2004
| Posted on Monday, February 02, 2004 - 09:01 pm: |
what are some good alternative options for HDTV in the same budget. I might go down to a 32-34" if it was a comparable price. thanks, Pete |
New member Username: Kes601
Post Number: 3 Registered: 01-2004
| Posted on Tuesday, February 03, 2004 - 09:00 am: |
I have a Samsung 30" Widescreen that was $900 at Best Buy last week. It does great with high definition signals and DVD. Analog is pretty good as long as the station has a strong signal. |
| Posted on Wednesday, February 04, 2004 - 03:08 pm: |
You might regret it in 3-5 years when HD becomes the standard and you have to buy a digital to analog converter (maybe your rented cable box will take care of that for you) or when you see something like the Superbowl in HD widescreen. You could just save up till then, prices will drop. |
