Thread: Recommendations on best DVD player w/DVMI |
New member Username: Hidefkindaguy
Phoenixville,
PA
Post Number: 8 Registered: Nov-04
| Posted on Tuesday, December 14, 2004 - 03:41 pm: |
Looking for recommendations on purchasing the best DVD player for the least money...the player must include DVMI for connection to our new Mits 62825. We have a fairly new Toshiba w/ proscan that does a good job, will upgrading to DVMI be a big improvement in picture quality vs. the component cable output? Am I wasting my money and should I wait to replace it with HD/Bluray next year? |
Silver Member Username: Mr_lynch
Seattle,
WA
Post Number: 319 Registered: Sep-04
| Posted on Tuesday, December 14, 2004 - 06:11 pm: |
Toshiba SD-5970. Upscales to 720p, outputs via HDMI and includes the cable. It can be found for well under $200. I've been very happy with the results go to my JVC DiLA via HDMI. |
Phoenixville,
PA
Post Number: 9 Registered: Nov-04
| Posted on Wednesday, December 15, 2004 - 09:22 am: |
Mr.Lynch, is the Toshiba deck limited to 720? I see other decks capable of 1080...is there a pc difference? Thanks! |
tvshopper Unregistered guest |
| Posted on Wednesday, December 15, 2004 - 09:39 am: |
Dennis, I also have the Tosh. No it is not limited to 720. On HDMI you can display 480 (?), 720, 1080 or 1240. |
Seattle,
WA
Post Number: 321 Registered: Sep-04
| Posted on Wednesday, December 15, 2004 - 11:26 am: |
I just listed 720p, since your TV (like mine) is a 720p native display. If you upscale to 1080i, the TV will have to convert it again. |
| Posted on Wednesday, December 15, 2004 - 09:46 pm: |
Dennis, DVI is relatively new and HDMI is even newer. So, most DVD player with these outputs is going to be on the higher end models and therefore cost a little more. I have a Mits WD-62725 paired up with a Denon 1910 DVD player. I use a DVI to HDMI cable and the resolution is outstanding. The unit can upscale to 720 or 1080. The 1910 has good reviews for an entry-level player with DVI output (run a search in the eCoustics review section). I am very happy with the unit ever since I figured out to TURN "OFF" the BLACK LEVELS control. The default is on the "ON" position and it degrades the contrast levels when the DVI cable is used. Denon has a reputation for excellent audio quality, which is another good reason to choose this unit. The 1910 retails for $249 and I have seen it going for the low $200's on line.
mastering Unregistered guest |
| Posted on Wednesday, December 29, 2004 - 12:28 pm: |
pls note i'd like an advise : i got plasma samsung tv 852*480 with dvi connection i need to buy the dvd player and i don't know if i should go for the samsun or denon 1910. price samsung dvd hd 948 : 3800 hkd = 380 usd around denon 2200 hkd : 300 usd wish one should i take ; AS SAmsung will be compatible with my tv but the denon not 100% sure . i'm also not really happy about the tv, so shall i trust again samsung ? my tv web http://www.samsung.com/he/products/tvplasmadisplay/plasmatv/ps_42s4s.asp the samsung new player : http://www.samsung.com/he/products/tvplasmadisplay/plasmatv/ps_42s4s.asp |
