Home > Message Board > Home Video > DVD Recorders > Archive through January 14, 2005 > Can Someone recommend a DVD recorder
Author Thread: Can Someone recommend a DVD recorder
IS
I am somewhat confused which unit I should get, I need to move lots of VHS to DVD so I need it easy, and have digital video that I need placed on, as well as record TV Shows easily(No Need for the TV Guide) Thanks
Maneshita
Try JVC DR-MV1S if you just want to record from VHS or DV to DVD.
If you want HDD then you can also try DR-MX1S
http://www.jvc.com/product.jsp?productId=PRD2000002&pathId=115
Username: Samijubal
Post Number: 535
Too many people starting to have problems with the JVC. Combos are poor quality units.
cyberhome go gog og go,.
Username: Scruffy787
I got a toshiba combo unit (the D-VKR3SU) and am having a problem watching a rented dvd on it - the aspect ratio can't be adjusted, so it looks squished. It's fine on my regular dvd player. Does anyone have any thoughts on this?
Username: Phantomdr
Post Number: 9
I got the Lite-On 5005 for X-mas and it works great! Reads and writes all formats and media except for DVD-RAM and the guider menu makes it easy to use. The only downside is it will not decode MTS stereo broadcasts, but that's not a problem for me since my cable box has A/V outs in addition to the RF. Not bad at under $200 Have a look... http://www.liteonit.com/DC/english/lvw_5005/lvw_5005.htm
Home > Message Board > Home Video > DVD Recorders > Archive through January 14, 2005 > Can Someone recommend a DVD recorder [ « Previous ] [ Next » ]
