Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Question to anonymous - pansat nagra2
Author Thread: Question to anonymous - pansat nagra2
Username: Plokk
If fta systems can't deal with nagra2, what do you think of what they say about max2000 here?
http://www.saveandreplay.com/dvb-Products.asp
plokk i won't even go there, many sites have claimed the same thing... it's all B>S
RobinHood
That's my question too. is there any chance the Pansat 2500a could be flashed in the future to support nagra2?
largo key
there is rumor that the pansat5000 will very soon be capable of receiving DTV and Nagra 2 through support from www.pansat.tv exclusively
Skoal_Spitter
FTA Receivers will not be receing Directv signals as Directv does not encrypt their stream with a true Mpeg2 encoding such as that used by Dish Network and Bell Expressvu. Using FTA for DTV simply isn't going to happen.
largo key
copy/paste from a well known coder...
The present Nagra1 system and the card image on the ROM cards is what FTA IRDs use for duplicating the decryption process. This is done by copying the ROM image to the FTA unit's EEPROM, very much like writing to a card. BUT, because the IRDs EEPROM can only be accessed by the serial port connected directly to a computer, that means that the EEPROM code cannot be changed through the stream like what happens when DN sends down an ECM and screws up the card. This makes FTA units very stable and less prone to ECMs and TV just keeps going and going.
What's important about Nagra2 is that it's more secure of a card and harder to access. However the Nagra2 ROM image can still be used on an FTA IRD, providing that the IRD has adequate memory and hardware functionality to support the new Nagra2 system.
The good news is that Nagra2 has been hacked. This guarantees that FTA will be around a long time. I am not 100% certain what this means to all present FTA IRD owners. In the case of Pansats, the 2500 will need a minor chip replacement, which shouldn't be more than $100 to get the 2500 Nagra2 capable. The chip will be ready when Nagra2 is ready and Nagra1 is no longer in the stream. I believe that the older 2300 IRDs may not even need this mod to be capable of dealing with Nagra2.
The new model 5000 won't need any modification and based on what I believe is good information, Dave will be in for a surprise very soon too and there won't be diddly he can do about it except to change out all the cards once again. The new Model 5000 will be capable of decrypting either Dave or DN but not both as I understand it. The days of hashing are going to be a thing of the past. It may take a little time to tweak the bins written to the IRDs but it won't be long until Dave runs out of options. My theory is that the ASIC HAS BEEN CRACKED. I can't see any other way of doing it. But, if I really knew for sure, I'd be in jail now. Just stand by. The coders are the best in the world.
GUYs THE FTA USES A CHIP CALLED ATMEGA128 to decryt the signal, IF THE ATMEGA CAN'T BREAK IT, OR SOMEHOW A WAY TO EMULATE THE WAy the card works, it cant be done, the atmega chip can emulate a rom3,10,11 for nagra1 but no idea how a flash/eeprom can emulate a rom 101-102-103(yellow ones. but as we know "theres always something"
cavitysearch
well, the pansat manufacturer desided not to release with the proper tuner to do dtv....the new software for the 5000 is out today at dsscentral
nagra2 has not been hacked!
Professor Chaos
Nagra 3 is on the verge of being compromised though. I heard it from a reliable source at the University of Kinmount smart card lab.
They were the prominent figures in hacking into Elton John's wardrobe room, which as we all know was running on "Sky" technology, which later became known over here as "NagraVision".
We just need to wait for the next swapout.
FreeTV Applebee
oh man I cant wait for all the gai channels to get hacked again on Nagra 3! This is good news people!
Username: Knee_grow
Post Number: 7
I wish these fa99ot apples would take a hike..If I wanted an apple I would go to the fridge and get one you retards...
Boris
WTF?? NAGRA 3??? hahahah fu*ckin idiots ... nag 2 is as far as it gets so far... there is no hack yet...and wont be till its out of the stream!
Boris
i mean till nag 1 is out of the stream* pardon me!
Boris
I mean till analman has his way with me
Hello
I would like to have some information or documentation on Pansats 2500 and how to program it, hack it
LK
www.dsscommunity.com has tthe files,manual,and help in forums and live chat..
- DTV ASIC IS NOT HACKED, NAGRA 2 IS NOT HACKED.
You all have "reliable sources" and theyre all bullsh1tters. I give my real name cause I dont spout lies off... I speak the truth. Besides if you're ANYONE in the dss industry you MUST know who I am...
- I AM EVERYWHERE AND NOWHERE... WHO AM I?
SeminolePride
btw DSSCOMMUNITY AND DSSCENTRAL suck...
LK
U are Kneegrow
Has anyone had any luck getting a DP Quad LNBF to work with a Pansat2500A? Seems to get 110 V+H but only 119 V. Any good ideas?
Yes, www.fta-software.com
Step by step instructions.
Username: Chichiboy
Yikes folks, I just ordered 10 pansat receivers, (for family memebers and two friends). Afterwards I stumble into your comments re: Nagra 2. I can loose my $, but, I won't loose my friends. Is there a possiblity the pansats may be useful again someday?? Thanks.
Username: Jmill1948
Chester, Va
Usa
Post Number: 547
you can count on it..................
Hey,
Bell is moving to the nagra2, will the Pansat 500Hc be abe to handle the new signal? We currently have a 2500A Is there any upgrades avalable for it?
The general
LK
NO nagra2 datastream hack is public,just like the P4/P5 cards datastream...so No hack,then NO TV
BTW...general,that was a "private" question...DSS 101...U've been demoted..
can you guys tell me,what receiver is the best to buy in this days and to work with dtv dish .because i am not sure what is going on in this moment around canada,toronto. thank you very much
Q
Anonymous the best FTA receiver going at the present time are the Coolsat models 4000+ and 4000Pro depending on your budget and needs. Check out Flea Bay, some good prices.
Home > Message Board > Home Video > Satellite TV > Archive through March 07, 2005 > Question to anonymous - pansat nagra2 [ « Previous ] [ Next » ]
