Home > Message Board > Home Video > Rear Projection TVs > Archive through January 15, 2005 > Mits WD62725 - Bulb Message
Author Thread: Mits WD62725 - Bulb Message
Username: Pitburger
Post Number: 21
Mine is about 3 months onld now. I am now getting a message on power on - "Has bulb been replaced?" Press enter for Y or Cancel for N
Anyone else seen this message or know why?
Username: Mldemeo
Riverside, CA
Post Number: 9
Rob Hilden,
I have the 52725. I saw that same message once after I had unplugged / replugged the TV from the AC wall outlet. After I replied no, the message hasn't reappeared.
Mike.
Username: Pitburger
Post Number: 24
I think I had short power outtages, probably the problem. i just hope its not a sign of a bad or deteriorating bulb....
PETE T.
ROB
THAT IS NORMAL IF THE THE POWER HAS BEEN SHUT OF OR IF YOU HAD A POWER OUTAGE.
PETE T.
Martyalien
This message will also appear if you use the reset button on the front panel.
JS
I think it can also happen if you remove the air filter cover which activates an internal switch that turns off power.
Username: Mr_daniel
Houston, TX
United States
the reason it does this is because the TV has a 4,000 hour timer in it. after that 4,000 hours it will display a msg that basically says your bulb will wear out soon and you should be ready to replace it. if you lose power to the tv it's basically asking you if you want to start the 4.000 hour timer over or not.
Home > Message Board > Home Video > Rear Projection TVs > Archive through January 15, 2005 > Mits WD62725 - Bulb Message [ « Previous ] [ Next » ]
