Thread: COX Cable |
New member Username: Retiredjetp
Post Number: 1 Registered: Dec-04
| Posted on Friday, December 03, 2004 - 11:10 pm: |
Does anyone know if it's legal for me to split my COX TV cable inside my house so I can run it into the next room and hook up another TV ? Chuck |
| Posted on Saturday, December 04, 2004 - 09:29 am: |
There is no illegality in splitting unscrambled basic cable that you have paid for. Using a 'cheater box' to descramble unpaid channels would lead you afoul of the law. |
Post Number: 5 Registered: Dec-04
| Posted on Tuesday, December 07, 2004 - 04:23 pm: |
Is it legal for me to open the COX cable box on the side of the house. One of the cables they installed goes to a room upstairs from the connector box, that room is now empty and I want to run that cable downstairs to another tv. Chuck |
| Posted on Tuesday, December 07, 2004 - 07:30 pm: |
If there is not a padlock you can change the cable connections on your splitter. (Just make sure you don't touch the neighbors connections!) |
Post Number: 6 Registered: Dec-04
| Posted on Tuesday, December 07, 2004 - 07:37 pm: |
>>Just make sure you don't touch the neighbors connections!)<< It's on the side of my house, my neighbor better not be hooked up to it. Thanks for the response. Chuck |
Post Number: 7 Registered: Dec-04
| Posted on Wednesday, December 08, 2004 - 02:01 pm: |
>>If there is not a padlock you can change the cable connections on your splitter.<< There's no padlock on the box, I'm talking about the one on the side of my house, not the one down by the street, I wouldn't dare go near that one. But even though there's not a padlock there is some kind of nut attached to what looks like a cut off piece of coax cable protruding out from the hole. How do I get it off? If you'd like i can try and take a digital pic. of it and post it. But perhaps you already know what I'm refering to. Chuck |
| Posted on Tuesday, December 21, 2004 - 08:15 am: |
Wise up. How much do they overcharge to donate millions back to our community? Do they use these same donations as tax deductions on local, state, or federal taxes? |
Post Number: 9 Registered: Dec-04
| Posted on Wednesday, December 22, 2004 - 09:22 am: |
I had no idea they donated money back to the community. I take back some of the bad things I have said about them. I wonder if the satellite tv companies donate also. Chuck |
New member Username: May
| Posted on Thursday, December 23, 2004 - 12:04 am: |
I'm glad April pointed that out about COX. My cousin works for them and he never mentioned that they are so generous and give to the community, I think that is great and more companies should do the same. MAY |
Ken Harkins Unregistered guest |
| Posted on Thursday, December 23, 2004 - 06:08 pm: |
what in the heck are you guys talking about? i thought this was a forum on home theater questions. i am also curious as to what the nut is connected to coax. does anyone have any ideas? |
