Home > Message Board > Home Video > Satellite TV > Archive through July 29, 2004 > NEW CARDS
Author Thread: NEW CARDS
I would like to know if anyone knows when the new P5 cards are planning come into the picture and take over the HU. Is it a good time to buy a P5 is the price going to go up like the Hu did when the H went down? HELP!!!
Does anyone know if it's worth purchasing the Avenger SE with the footbal card or will it work with other cards as well?
Username: Bluez
Post Number: 19
the price for a p5 through dave is 0 and i dought it will go up
you can get a couple of them with a multi room system assuming you are american
why buy any where else
when people start selling off there hu equipment it is a sign that the new card loaders are starting to trickle out but not a sign of death for the hu
hu here was 180 cdn when the h went down and after it was 180 cdn but since november they have gone down to 150 cdn
romurs of loaders doing p4/p5 in southern ontario
scammers use this info to take advantage but if you study the past you can get a feel for the future and not get taken
avenger se has a site or a forum
do a search
Anyone know where I can find any free or cheap 3m bin files????
Does anyone know how to use the HU cards with a SamSung system that is currently using the new P5 card. When inserting the HU card it is telling me that card isnt compatible.
Jbird
dsscyber.com fairly reliable. good prices for scripts
al gien me pude desir sitienen targetas nuevas de
directv selos agradeseria
My HU Card is currently getting a "not a valid card" message. I have heard HU cards are no longer valid. They can not be reprogrammed. Does anyone else know about this?
JayG
Direct Tv has started pulling the HU data out of the data stream. By the end of April, the HU cards will be useless! They are slowly shutting them down channel by channel. Soon only P4 and P5 cards will be able to access Direct TV.
Username: Sweetmisery
What is the difference between a P4 and P5 card?
I would like to know which card to buy , and the difference between them "the P4 & P5" ? Also does anyone know if the Mikobu 111-M6.2 will work with the P4 & P5 cards ?
tom.t
I'd also like to know the difference between the P4 and P5. My system is a Hughes Digital and I am confused about which to get
Username: Giovanni
Bronx, Nyc
Usa
Post Number: 14
According to the ATR analyzer in Winexplorer, P4 clock 5 mhz, the same as P3
ATR: 3F 78 13 25 03 40 B0 20 FF FF 4A 50 00
Convention: INVERSE
Protocol: T=0
TA1 = 13
TB1 = 25
TC1 = 03
Historical Bytes: 40 B0 20 FF FF 4A 50 00
@ ° ÿ ÿ J P
Programming Voltage = 5.0 volts
Programming Current = 50ma
Maximum Clock Frequency = 5.0MHz
for Hu=P3
Historical Bytes: 38 B0 04 FF FF 4A 50 00 00 29 48 55 55 00 00
8 ° ÿ ÿ J P ) H U U
Username: Giovanni
Bronx, Nyc
Usa
Post Number: 15
i had a ulpro h unlooper. turned out all i had to do was jump some wires to the amtel. Then flash the unit to the new flash that was out at the time i think it was tritonHU and we where able to load cards.
There will be a lot of scammers out there people. Dont buy anything unless you talk to some one before hand. get people to find out more info for you as well. dont go and buy something that claims to do p4.
I'm just thinking there has to be a few major players around still keeping low and will pop there heads out of the sand sooner then we think. All it takes is the key to get in and more people will keep the files comming.
Maybe some new face will pop up and make some break in the p4 never know but hey i will be waitting for the time it does.
also look at this. The hu loader that came out frist was so much dam money that some person bought one and then copied it and made it freeware. after that files where going on the web faster then anything i seen before.
Username: Giovanni
Bronx, Nyc
Usa
Post Number: 16
This is a cut and paste that i got from another site. You be the judge.
Here is a little more from my friends
(name withheld)
I saw the completed P4 loader today. It has been sent out for production. Here are a few tidbits on the new loader.
1. The P4 loader does not have a atmel. It has a PiK instead.
2. There is a knob on the loader that controls the clock cycle speed.
3. The person who demontrated the loader said it runs at 40 times the speed of the hu loader.
4 He said the hu loader cannot be updated to do the P4. It is a complete different design.
5. The loader loads the P4 with a wide open 3m quickly but due to the need to turn the knob to adjust clock cycles it is a bit slower than we are use to.
Please do not bombard me with phone calls and emails about this. As I am able to give information I will.
This is all I have right now negotiiations are very tight lipped. This unit should come in under 1k
The only other info I have at the moment is that your old loaders won't be upgradeable
Username: Giovanni
Bronx, Nyc
Usa
Post Number: 17
First of all I do not understand the choice of a pic over an atmel as
it really gives you no advantage. The main thing in the hacking of the
P4 card is overcoming the built in glitch prevention engine. To do that
you MUST provide glitch's that are beyond it ability to control or in
this case protect against. As a point to start from we find that the HU
loader and unlooper ran at 4X that of the cards clock so with a 4.6MHz
clock we find that 4 X 4.6MHz equals 18.4MHz they used 18.432MHz as it
was available and it could be reduced with math to a freq that would
provide a usable baud rate so it could communicate with the pc thru a
serial connection. So now if we take this same number X4 and apply it
to the P4 card we find that 12MHz X 4 equals 48MHz but 48MHz is a royal
pain in the #$%&@* to use and still divide diwn to a usable baud rate but
if we were to lets say take 18.432MHz and use 3X that freq we would be
at 55.296MHz and that is better then 48MHz so it is fast enough plus if
you were to lets say take the original UL4S code and port it to the
micro I am using and then added a divide by 3 to the divider routine to
generate a good baude rate you would be at the same baude rate as you
were originally when you used the 18.432MHz but you would actually be
running at 55.296MHz. But the next problem is that the original ic's we
used in the design of the h unlooper and then the updated unit the HU
loader unlooper are too slow to handle the new higher frequency. But I
just changed them all to the VHC family of ic's actually my HU loader
unlooper I mnf'd and sold actually already used the VHC parts where a
HC4053 was being used by everyone else. So I just had to change the 1
osc ic from a 74HCT04 to a 74VHC04 though I could have used a 74F04 IC
and just draw more current but I didn't because I had the correct part
the 74VHC04. I changed the 2 74HC74's to 74VHC74's and I changed the 2
74HC00's to 74VHC00's. I also changed the LM358 to a way faster and
wider bandwidth op amp in fact it is changed to one with a very high
slew rate and it is really a comparitor more then an op amp but that is
not the point here any. So we now have an updated unlooper loader that
is now running at guess what 55.296MHz vs 18.432MHz but what about the
micro will an atmel go that high? NO, will a PIC? NO! What then? Well I
used a nice part from scenix which can be bought thru parallex. It is a
SX20AC/SS. It is only available in a SOIC package so it is soldered on
a adapter board that does 2 things, it adapts the smt package to a dip
package and it allows for the i/o lines to be moved to match the old
atmels pinout. So now this adapter board plugs right into the old atmel
micro's 20 pin dip socket and the pins are adjusted so they go to the
correct pin location of the older atmel chip. So with that all done the
next job was to take the disassembly of the UL4S atmel code and port it
for use in my new scenix micro and to change the routines that divided
the clock down to generate the needed baud rate for communications with
the pc thru the serial port. Then I played with the constants as I was
not happy with the min and max of the 6 adjustable operations. So I did
a little R&D and came up with a min and max number that was good for me
and the asic. I then reassembled it and burned my new micro for some
testing actually a hell of alot of testing. Now I too considered the
use of a pot to adjust the pulses duty cycle but found that a few small
changes in the micro's code and I was able to satisfy my needs though I
guess I could still add on a pot to theak in the acyual duty cycle.
REMEMBER this is just work in progress but last night I did actually
glitch into the P4 card but I could not for the life of me get my code
to load. The code is my turoloader code which is just the name for my
fancy bootloader code which I borrowed the name turboloader from AOL's
code for the H card that made writing to the H card a very fast thing.
It is basically using arrays to send the data w/o the need for header
info as that is stripped of of the data before it is placed into the
array. But anyway I could not get it to take my bootloader code but I
will keep on trying because I know it will work one day soon. This is a
project that I just took on for a friend who is now in a wheelchair and
is soon not going to be able to walk at all so he wants to come up with
something he can make a dime on but he would settle for just saving the
day like underdog. In fact underdog is his hero & my hero and has been
so for a long time. So anyway I just wanted to share an idea with all
of you and maybe from this and other posts from other hobbiests some of
us might get lucky and strike the motherload.
But here is a point I want to make, if the design he is talking
about in the 1st post of this thread is really running at greater then
20 times the speed of the original atmel then we are talking 96MHz or
192MHz and that is not possible with any pic micro. In fact I think
they go up to a max of 20MHz or maybe a bit more but not anywhere near
the speed we need for a good unlooper/loader but agin I may find out
that I too am running too fast and have to slow down though I doubt it.
So just think about it, a pic running at 20X of that of an atmel? But I
could be wrong.
Now as for the question about the pic being In circuit programmable yes but it depends on which chip was selected. If it has a F in the part number then it is a flash chip and it is in circuit programmable but if they picket a C version then NO it is not, but the pic's are easy to cut the top off of and rebond the blown fuse and read the code back out. The atmel is a bit harder.
Anyway good luck to all. BAGGS
Username: Giovanni
Bronx, Nyc
Usa
Post Number: 17
could be wrong.
Username: Giovanni
Bronx, Nyc
Usa
Post Number: 18
Thanx, I do have a dtv alternative idea.........
For those that have a used p4 or p5, Black Shadow is a no745 board that works (reactivates) canceled P4's & P5's From thier ad....
The new Black Shadow No745 Bootstrap Board Technology "The most flexible solution". Very simple to use. Program HU Card like normal using any blacklisted bin and a good working 3M or activation. Insert HU Card into the Black Shadow Bootstrap, and finally insert Black Shadow NO745 Board into receiver and reboot receiver by unplugging for 15 minutes.
Product Features
Simply the best and most powerful no745 Spoofer board you can buy!
Programmable with Proprietary Shadow Software
NEW CAMID generated every time you insert it into a receiver Over 68,000+ CAMID combinations on-board
Upgradeable flash through any HU loader with UL4S
Manual CAMID input - Ability to use F, H, HU, P4 and P5 CAMIDs
Compatible - 3M / Activation / Avenger SE / WonderBox / Emulation
Ultimate TV enabled, programmable - even if your script isn't
Block Tier Wiping enabled, programmable
All surface mount technology
Atmega 128 micro controller technology - fastest for the fastest stream and larger capacity chip than other boards.
P4 and P5 Enabled it allows cancelled P4 and P5 cards to continue to work in your receiver.
This is confirmed. You would NOT have a fully open 3m'd card, but you would have TV! I am currently checking with the company to see if they are offering a ppv wiper That wouldn't be so bad!
Do a google search on Black Shadow to get the url if interested. thesatshack has em.
Please testers, let's ALL stick together on this till we get some answers! Stop bickering!
DKNY
So Giovanni, should HU (P3) cards be used as fire wood starter or can then be used for anything?
do you think hu cards will be able to hold the information that p4/p5 will kinda like hack it or somthing
Anony
Hu cards will be totally dead by Tuesday or Wednesday. They are garbage now.
Any idea when there will be a program for the P4? I have heard rumours that it could be years...miss my dish already. Please HELP!
hi newbie here.i would like to thank all of you for the information you have posted..i would like to start testing my system with the p4 card can somone suggest what equipment i will need...remember the simpilar the better....should i wait to buy hardware until there is a fix for p4 sorry for so many questions but i have to learn somewhere.......thanks again jmill
this is a cut a past....... Barring any unforeseen events, DTV expects to have the HU card datastream turned off completely by April 27. Users should consider getting a basic subscription from DTV in case a fix is not available by that time or making other arrangements for TV viewing in case a fix is not ready by that time.
2. A flash* MAY be available as early as next week which will convert almost ALL existing programmers to enable them to program P4 cards. Some older programmers such as T6 Typhoon, Red Dragon and Kick A-- may not be able to take the new flash. The programmers most likely to be easily upgraded are: Mikobu III, A--Kicker, Aftershok Plus+, Aftershok, Xtreme Sureshot, T911, Detonator XP and Detonator II.
* A flash is a small program that will update the Atmel (the 'brain') inside your programmer. The process usually takes 5-15 minutes.
3. A fix MAY be available for P4 cards as early as next week. Provided that the flash (mentioned in 2 above) becomes available before this, all users SHOULD be able to program P4 cards at home just like HU cards.
4. A fix for P5 cards MAY take anywhere from 2 weeks to 2 months longer to become available.
Although all this information has come from very reliable sources, none of it is confirmed and should be treated as strong rumors only. It is presented here only for those of you who are very anxious to know exactly what is going on at this time.
Our recommendation to all customers is still to simply wait and see what really happens.
my loader did the H and HU cards. will it work for the P4 and P5 cards.?
Herc
Don't be fooled by people trying to sell you P5 cards.
The whole reason for the P5 is because of a security flaw in the P4
As of now the P5's are useless. Get your P4's now before the prices skyrocket. April 27 is the last day for the current HU cards.
RaiderNation
My channels 2-100 still work. Missin the deng Laker game on TnT though ;(
P4
anyone knows if there are different kind of P4 cards being offered? and what is differnet?
secret
I just want to watch tv, can anybody help
HOUSTON, WE HAVE A PROBLEM!
mondo
Can someone tell me why the p5 is useless??? and futhermore can someone tell me the difference between the p4 and the p5. and i wanted to purchase the p5 card instead of the p4, is that a wise decision? can someone be informative in there reply thanx
BLACKBIRD/SILVER BULLET. Are these FTA boxes really work? Can they be zapped by DAVE or provider.
me again
vendor plans to sell programmed P4 cards. end users who can either buy a new programmed card or send in their own P4 card for exchange. There is no indication yet on a price for new cards or exchanged cards.
We are cautiously predicting that one of these solutions will be available by around May 5th.
A friend claims to have the hack.
they have a real suscribtion and made an exact copy of it now he is sellin the card for $200cnd and the file for $75cnd. he claims to have a programer that works made by himself he is an engineer
anonymous......email me if the card and program work i would like to get in touch with you or your engineer im interested in purchasing.... jmill1948@aol.com how much is that in usa
lovehockey
Can I get just the P5 card? If yes, then who sells it alone?
Username: Stopmenot2002
Unknown, Texas
US
P4/P5 Crackz http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=11726&item=3094337525&rd= 1
I have a question that might get an answer here.I have a set of Hughes receivers with p4b cards that are subscribed. I took one of the units south below California to a place we stay and could only get a couple of Directv add channels..No thing else. A freind told me he had the same problem with a newer reciever and brought an older unit down and it worked fine.. Tried a friends reciever on my dish set up and it worked fine... Is it the reciever unit with a filter? marty
Marty, I don't know what's going on here but there is a lot going on that is not being blown out. My brother-in-laws told me that his buddy is selling p4 cards with bins that are still working for $175. He told me that he himself lost all his channels on Wednesday, however, he still has all the sounds from EVERY channel including PPV. How can this work? According to B-I-L, his buddy has about 50 regular customers that still have access to Direct TV. I gave him my p4 card and told him to have his buddy program it and see what I get.
Hey anonymous please keep us updated on that P4 card
jobob
did you get your P4 card back yet and if so was it a success???
kong
the only card selling in london canada is the p5 my dealer wont seel the p4 hes losing money ifthe p5 cant be programed hes telling everyone at his shop hes programing our cads on the 30th
kong
can anyone tell me if this is bull or what?
ballerf
i have p5 for sale 125 cdn.
justcurious
ballerf if u r for real y r u unregistered?
Username: Adekunle
Ejigbo, Osun
Nigeria
credit card
Home > Message Board > Home Video > Satellite TV > Archive through July 29, 2004 > NEW CARDS [ « Previous ] [ Next » ]
