Thread: Copying DVD to DVD recorder with internal harddrive |
| Posted on Saturday, November 13, 2004 - 10:09 pm: |
How can I copy dvd's using only 1 dvd player. I want to use my dvd recorder to play the dvd and record it to my harddrive then record it from my harddrive to a dvd rw disc, but there is copy protection so does anyone know if or how a video stabilizer will solve my problem or do i need to use another dvd player with my recorder? Thanks qwerty |
Silver Member Username: Samijubal
Post Number: 428 Registered: Jul-04
| Posted on Saturday, November 13, 2004 - 10:12 pm: |
Take that stabilizer money and buy a burner. The PC will make far better copies even if you shrink them, if you don't shrink it will make perfect copies. |
| Posted on Sunday, November 14, 2004 - 01:33 am: |
thanks for that idea but my computer is a pile of well i'd rather not say and it would more expensive to upgrade it to do more than slowly burn cds Do you know then if i can copy dvds using only 1 dvd player with the internal or if i have to hook up a second dvd player? thanks |
Post Number: 432 Registered: Jul-04
| Posted on Sunday, November 14, 2004 - 02:32 am: |
If they are retail DVDs you would need a seperate player and a stabilizer, if they aren't retail then you can do it all on the recorder. |
| Posted on Sunday, November 14, 2004 - 02:58 pm: |
Great thanks alot! |
| Posted on Sunday, November 14, 2004 - 09:32 pm: |
Do you know if the Sima stabilizer removes macrovision? Or I guess which stabilizer would you suggest? Thanks again |
Post Number: 437 Registered: Jul-04
| Posted on Sunday, November 14, 2004 - 10:27 pm: |
It's supposed to, I haven't used one. It depends on the recorder as to how sensitive it is to copy protection. I've got a $20 cheapo stabilizer I've had for a decade that will only work with videotapes not DVDs when using the Panasonic DVD recorder, works fine on DVDs with the JVC though. |
| Posted on Wednesday, December 22, 2004 - 02:38 am: |
Much like when you connect a VCR to a dvd recorder, can you connect a dvd player to the recorder and copy a dvd movie. i know there is an encryption protecting you from doing that but is there a way to get around this without using a computer (mine is no good). by the way my dvd recorder doesnt have harddrive built in. Thanks. |
| Posted on Wednesday, December 22, 2004 - 11:53 pm: |
Yes. Go to: http://www.dimax.com/ Pick the DVD Red PRO. It'll get rid of the macrovision/copywrite protection. Well worth the money! Check out their compatibility list, and if you don't see your DVD Recorder on there, just E-mail the staff and ask if your DVD Recorder is compatible or not. I only hear good things about this product. |
Dave JSV Unregistered guest |
| Posted on Wednesday, December 22, 2004 - 11:54 pm: |
Sorry, that would be: http://xdimax.com/common/default.html |
| Posted on Thursday, December 23, 2004 - 03:10 am: |
Thanks alot for the help. I appreciate it. |
