Thread: LG Sony hookup woes -- help please |
New member Username: Chris123
Post Number: 1 Registered: Oct-04
| Posted on Sunday, October 31, 2004 - 07:08 pm: |
I have a Sony high-def TV and just got an LG DVD/VHS player/recorder. I'm trying to hook up the thing and can't get the TV to operate. (The DVD and VCR play and I can get the TV stations when I manually switch the stations. The LG remote control turns things on and off but won't change channels). The hookup I am using is: 1. Cable from wall to the DVD/VCR in 2. Progressive scan cables from DVD/VCR to TV (Video 5 is the input that works.) Any help would be much appreciated.
Silver Member Username: Samijubal
Post Number: 371 Registered: Jul-04
| Posted on Sunday, October 31, 2004 - 08:34 pm: |
The VCR has to be hooked to the TV seperate from the DVD. |
Post Number: 2 Registered: Oct-04
| Posted on Sunday, October 31, 2004 - 10:18 pm: |
The DVD/VCR is a combo. I have played around with it enough that I can get it to play except for some reason, the LG DVD/VCR will turn the television on and off but it won't work the volume or the channel thing that goes up and down one number. |
Post Number: 374 Registered: Jul-04
| Posted on Monday, November 01, 2004 - 09:16 pm: |
So you are trying to operate the TV with the DVD/VCR remote, is that what you're saying? |
