Thread: 2 vcrs to record separate channels? |
New member Username: Lazulite
Post Number: 1 Registered: Oct-04
| Posted on Tuesday, October 19, 2004 - 11:11 pm: |
Hi, Is there a way that I can chain 2 vcrs together and have them both program to record different channels at the same time? Thank you, |
Silver Member Username: Samijubal
Post Number: 339 Registered: Jul-04
| Posted on Tuesday, October 19, 2004 - 11:14 pm: |
What are you recording from? Use a splitter and connect to both VCRs. |
Post Number: 2 Registered: Oct-04
| Posted on Wednesday, October 20, 2004 - 09:03 am: |
Thank you, that is what I figured I would have to do. I have a splitter that I can run from the tv to split the 2 vcrs. I was hoping that I could just chain them together, but I figured that would interfere with their individual programming. Thanks a bunch! |
Post Number: 3 Registered: Oct-04
| Posted on Wednesday, October 20, 2004 - 09:05 am: |
Oh, to answer your question, I wanted to be able to program timers on 2 different vcrs, attached to the same tv, to record 2 different tv shows. |
