Thread: Hooking up DVD Recorder to TV and DVD Player |
New member Username: Loveshoes2
Post Number: 1 Registered: Oct-04
| Posted on Tuesday, October 12, 2004 - 08:41 pm: |
Our current hook up consist of: We have a RF modulator, dvd player, dvd recorder, and TV hookup. The (Composite Video) red, white, yellow plugs are in the Audio input on the RF Modulator going to the DVD Player red, white, yellow output. The cable from the back of the TV is plugged into the RF Modulator TO TV plug. The cable from the wall is plug into the ANT IN plug on the RF Modulator S Video output on the DVD Player is plugged into S Video input on the DVD Recorder The DVD player plays, but the DVD recorder will not record. Please help
Silver Member Username: Samijubal
Post Number: 309 Registered: Jul-04
| Posted on Tuesday, October 12, 2004 - 11:17 pm: |
You can't copy DVDs they are protected. |
Post Number: 2 Registered: Oct-04
| Posted on Wednesday, October 13, 2004 - 08:48 am: |
I know you can't copy DVDs from the store. I'm trying to copy a DVD from a friend that she transferred photos from VHS. I'm trying to copy from the TV as well, but the hook up is not correct. Please help. |
Post Number: 311 Registered: Jul-04
| Posted on Wednesday, October 13, 2004 - 02:16 pm: |
On my recorder I have to set it on s-video to use the s connection. You don't say what brand of recorder you have. |
Post Number: 3 Registered: Oct-04
| Posted on Wednesday, October 13, 2004 - 02:57 pm: |
I have a Pioneer DVR-220 DVD Recorder. I was able to fool with it enough to get the setup menu to display on the screen, which I could not do before. |
Post Number: 314 Registered: Jul-04
| Posted on Wednesday, October 13, 2004 - 08:11 pm: |
Are you setting the recorder on whatever input the DVD player is connected to? You may have to set it in the menus to s-video. |
Post Number: 4 Registered: Oct-04
| Posted on Wednesday, October 13, 2004 - 10:15 pm: |
I can't set this on my menu. Any other ideas? |
Post Number: 315 Registered: Jul-04
| Posted on Wednesday, October 13, 2004 - 10:31 pm: |
Is the recorder set to whatever input the player is connected to? |
