Home > Message Board > Home Video > TV Basics > Archive through October 13, 2004 > Rear Projection LCD vs. Flat Panel LCD
Author Thread: Rear Projection LCD vs. Flat Panel LCD
Username: Jditch
What is the difference besides the fact that one takes up less space than the other? Are there differences in picture quality?
xvxvxvx
"What is the difference besides the fact that one takes up less space than the other?"
Literally thousands of dollars difference for a comparable size screen. A 42" RP LCD display can be purchased for under $3000, the same flat panel if available will cost twice as much.
xvxvxvx
Home > Message Board > Home Video > TV Basics > Archive through October 13, 2004 > Rear Projection LCD vs. Flat Panel LCD [ « Previous ] [ Next » ]
