Thread: Atmega setting guide |
New member Username: Nazarhm
Toronto,
Ontario
Post Number: 1 Registered: Oct-04
| Posted on Friday, October 08, 2004 - 08:34 am: |
I need help for a new Atmega 128 Card system .request for all in steps please...thanks
New member Username: Mrjinx
Nova Scotia,
NS
Post Number: 1 Registered: Aug-04
| Posted on Tuesday, August 17, 2004 - 10:12 pm: |
Hi everyone... just about to try my atmega card 128 with my bell 3100... can someone please verify that my steps are correct... thanks! first I want to hook my jtag up to the 3100 and save my tsop in a few safe places... then i want to program my card with the latest info and give it a whirl... so when I get an ECM... i want to hook my jtag up to the 3100 and re-install the tsop i saved and then reporgram the card again. Just want to make sure i'm clear on what to do. I'm pretty sure I need to save my tsop and refresh it to the saved version everytime I am hit correct? Thanks for your time Jason
Silver Member Username: Fryguy
Barrington Passage,
Nova Scotia
Post Number: 112 Registered: Jun-04
| Posted on Wednesday, August 25, 2004 - 07:11 am: |
Basicly thats right but to save yourself the headache install a d-lock then unpluging the IRD and pluging it back in resets the receiver. Its stops direct writes to the TSOP so if ECM's are happening you dont have to re-flash or do a SA erace to recover from the ECM. |
| Posted on Saturday, August 28, 2004 - 08:25 am: |
can you tell me what i am doing wrong programing my atmega 128 it keeps on saying failed to enter program mode how can i fix this |
Barrington Passage,
Nova Scotia
Post Number: 144 Registered: Jun-04
| Posted on Saturday, August 28, 2004 - 02:04 pm: |
check your cable and the lock/fuse bits "Lock/fuse settings Here is the lock settings for the ATMega 128 and a little proceedure that helps set these back to default. LOCK BITS - all checked FUSE LOW - All checked but BODEN and SUT0 FUSE HI - OCDEN, EESAVE, BOOTRST FUSE EXTENDED - both checked [FF][AF][89][FF] ALONG THE BOTTOM 1. Load up jeepers, and plug everything in for your atmega as normal (ie atmega in programmer, plug cable into compurer) 2. make sure jumper is ON 3. click the atmel tab, ATmega128, erase/flash eeprom 4. when it says erasing eeprom, PULL THE JUMPER 5. Do this 3 or more times 6. then do full monty, when it says erasing eeprom, PULL THE JUMPER, and when it says writing, PUT THE JUMPER BACK ON 7. You will get errors, go back and repeat steps 3 to 6. You will notice that each time you do the full monty, you will write a little more to the card before you get an error. 8. eventually you will write the card, and you will be able to erase the eeprom WITHOUT PULLING THE JUMPER 9. your atmega is fixed. Always program at the correct frequency Some people had to do this 2~5 times others I have heard take up to 20 times....Good luck." If you still have this problem then the atmega chip is no good, replace the chip or just buy another card. |
Nova Scotia,
NS
Post Number: 3 Registered: Aug-04
| Posted on Saturday, August 28, 2004 - 07:34 pm: |
thanks for the info! i would love to install a tsop lock but unaware of anyone around my area that is using one or knows how to install... any good ref guide out there on the subject? I don't mind doing things myself as long as I have good documentation... very determinded person ;) lol |
Unregistered guest |
| Posted on Sunday, August 29, 2004 - 10:30 pm: |
Moved my 3100 today when the wife came home with a new stand for the equipment. Long story short, all cables back in place but I am no longer getting any video feed from the box. The lock switch was moved for a few short moments durring the move. I re-checked all the cables, and re-programmed the atmega128 without issue - but the 3100 seems to be stuck in some kind of loop. Any suggestions on how to re-set? |
Nova Scotia
Post Number: 147 Registered: Jun-04
| Posted on Sunday, August 29, 2004 - 11:03 pm: |
whats on the screen? What do you mean by a loop? If you mean its stuck on accuiring satellite signal try the following. "Get to the system info screen (sys info button on the remote) and your firmware should be E469. If its not un-plug your IRD and turn your locks off. Plug back in. Then you have to wait with the power off (without the green light on but still pluged in) for it to update (green led will come on but with no picture then start blinking) this can take some time (10 min to a few hours or so). The easiest way to update it to do a erace of SA3 with a j-tag and j-keys. This will force it to take an update. also while your on the sys info check if your location ID is 0000001 i doubt this is the case. post your findings please." |
| Posted on Monday, August 30, 2004 - 09:56 am: |
Sorry Jonathan - as a newbie, I am sure my original post was less than perfect. Nothing comes onto my screen at all. It seems as if the video cable is not connected - but of course, it is. I do get the flashing LED light though - so perhaps I just have to wait for it to update? The 3100 will not respond to the remote, and the only way to turn the LED (power) off is to either hold down the power button or unplug the power cable. How best to proceed? |
| Posted on Monday, August 30, 2004 - 05:18 pm: |
my jumperless atmega 128 says atmel part is not atmega 128, what is going on??? |
Nova Scotia
Post Number: 150 Registered: Jun-04
| Posted on Monday, August 30, 2004 - 06:17 pm: |
no video signal, I would say your IRD was hit or it was unpluged during a TSOP update. Either case its not good. The only way to fix this is to get very familure to the use of a J-tag and the program J-keys. To force an update you'll have to erace SA3 for the 3100. If this dont work then you'll need to do a full manual flash of the TSOP's firmware. |
Nova Scotia
Post Number: 151 Registered: Jun-04
| Posted on Monday, August 30, 2004 - 06:21 pm: |
jacobHU, I hat to say it but if you know your cable is fine and you cant even get to the lock/fuse bits (without getting the error). Its a indication the the Atmel Atmega128 chip has died a miserable death. Replace the chip (If you can do fine pitch soldering) or replace the card.
| Posted on Saturday, September 11, 2004 - 08:05 pm: |
Has anybody encountered a problem with an Atmega 128 -card being to short to make the proper contacts in a bell 3100 ? |
Nova Scotia
Post Number: 179 Registered: Jun-04
| Posted on Saturday, September 11, 2004 - 08:50 pm: |
Can't say i have ever heard of that problem. If a chip is hitting then its a bad card design (Be sure the contact side is down 'and its the component side also' when inserted, i know it may sound stupid but i have found that to be the problem with a few other PPL's cards, they were inserting them in wrong ) |
| Posted on Sunday, September 12, 2004 - 12:01 am: |
Having problem using jeepers, programming atmega 128 All the information, keys etc seem to be right, but won't enter program mode. Checked my parrallell port config and it matches jeepers settings. Card is brand new, out of the box. HELP |
New member Username: Barrynash17
Post Number: 1 Registered: Sep-04
| Posted on Wednesday, September 15, 2004 - 11:33 am: |
What I did to fix "can't enter program mode" Reset my BIOS to system defaults to make sure that LPT is addressed to 0x378. Used a gender changer ($5.00 @ Staples) male/male and plugged my card directly to the back of my PC. This was done after three days and many attempts. Works great. |
Nova Scotia
Post Number: 184 Registered: Jun-04
| Posted on Wednesday, September 15, 2004 - 03:31 pm: |
I doubt the problem had anything to do with the LPT port address being changed to the default 0x378 didn't have anything to do with your problem. You could have changed it to the port address you were useing in jeepers settings. The problems i have seen in the past was the port mode (ECP,EPP) one mode or the other will poser the card better and also having the inproper or a cheep cable. They male to male cables need to be pin for pin, some computer shops have the data cross-over cables that look similar. The cheep cables dont have all 25 conductors, printers only use 8-10 conductors and they don't bother put the others because they realy arn't needed. unfortunatly the few wires they don't include are needed for the programer to work. (I cant remember if it was a few power or ground wires or exactly what the pins were) The direst connection is the best way, cant get the wire any shorter to avoid power loss that for sure. Post feedback on my statement, it will help others with the same problem. |
New member Username: Patsyrick
Miramichi,
NB
| Posted on Thursday, September 16, 2004 - 06:41 pm: |
We have a 2700c with an atmega 128. We lost our signal last night. Can someone help us? We are new at this, in fact this is the first time we've been on the site to ask a question. |
Nova Scotia
Post Number: 191 Registered: Jun-04
| Posted on Thursday, September 16, 2004 - 10:36 pm: |
Please hit your system info button on the remote and tell me if at the bottom of the screen you have location ID 00000001, if you do your not going to like it. It can be fixed but not all that easily. |
| Posted on Friday, September 17, 2004 - 12:33 pm: |
All i can get is black screens and a few free channels with an atmega 128 with 18.42 crystal in a 3900 receiver. Any ideas one whats wrong? |
| Posted on Friday, September 17, 2004 - 02:08 pm: |
I just bought an Atmega 128 and I don't know what to do with that. I don't know much about electronics. I'll appreciate if anybody can provide me with a site that I can go and learn from a guide. Thanks. |
Nova Scotia,
NS
Post Number: 8 Registered: Aug-04
| Posted on Friday, September 17, 2004 - 04:13 pm: |
Atmega 128 - location ID of 00000001 isn't bad to fix if you have a jtag anyway! If not better find someone who does  |
Nova Scotia,
NS
Post Number: 9 Registered: Aug-04
sss just look for an atmega guide on dishnewbies.com it's easy to do |
Nova Scotia
Post Number: 194 Registered: Jun-04
| Posted on Friday, September 17, 2004 - 04:27 pm: |
JCH, My referring to it as not being easy, was from the eyes of a newbie. Most people aren’t that technically inclined or even familiar/comfortable with computers. Then throw in some wires and a rather complicated program (J-keys) and what do you have. A heck of a confused newbie that’s what. While me any you could most likely do it blind folded. |
Nova Scotia,
NS
Post Number: 10 Registered: Aug-04
| Posted on Friday, September 17, 2004 - 08:09 pm: |
yes true... i see your point! sorry for coming across as a know-it-all  |
Nova Scotia
Post Number: 195 Registered: Jun-04
| Posted on Friday, September 17, 2004 - 08:24 pm: |
No problem at all. It’s easy to forget what it was like when we didn't know anything and were new ourselves. Now when I get asked a question that seems stupid to me I constantly have to remind myself that “There isn’t a stupid question, other then one that wasn’t asked”, also “There isn’t stupid questions, just stupid people” I think that’s because they don’t ask questions to learn the answers. :-D |
Bronze Member Username: Mrjinx
Nova Scotia,
NS
Post Number: 11 Registered: Aug-04
| Posted on Saturday, September 18, 2004 - 07:58 pm: |
haha yes very true... fryguy... any idea when the last ecm was done on atmegas before Aug 13? Just curious... starting using atmega in August and was just curious how often they did the ECM over the past few months. Thanks! |
| Posted on Wednesday, September 22, 2004 - 03:45 pm: |
Having problem using jeepers, programming my atmega 128 1. have gender bender and cable (25-pin) 2. Using Jeepers ver 2.1.2 (build 020) 3. parallel settings are set for Bi-directional, or Normal. 4. Running windows 2000 5. Have never been able to get it to work Jeepers sais :" failed to enter program mode" Help Please |
Nova Scotia
Post Number: 209 Registered: Jun-04
| Posted on Wednesday, September 22, 2004 - 04:50 pm: |
1: Check your lock/fuse bits, lock/fuse bits need to be right before you can write to the card. 2: Try diffrent port mode in the BIOS (ECP,EPP,ECP+EPP,etc) some will give better results by powering the card better. 3: Remove the cable and plug directly into the parellel port (with a gender adapator if needed). You may have accidently got a crossover cable (DCC cable)or a cheep cable that don't have all 25 wires pin for pin. 4: Check what your HEX address for the parellel port is (in control panel/advanced tab, usualy its 0x378 for LPT1) to be sure you have the right port selected in jeepers. Thats the most common problems. If they dont work then you may need a powered cable or your card is locked or it's fryed (thats a pun). |
| Posted on Friday, October 01, 2004 - 07:49 pm: |
i need help i need latest keys if you have can you please send me email on arslannaseer@hotmail.com or arslannaseer20022001@hotmail.com |
New member Username: Johnnyk
| Posted on Sunday, October 03, 2004 - 04:54 pm: |
Can you tell me what I am doing wrong. I have 8 atmega 128 programes. I have connected direct to he printer port with 6 feet cable.When I try to erase/flash it keeps saing failed to enter program mode. I'm trying to go to Lock/Fuse settings and say the same thing failed to enter program mode. How can I fix this. Please Help. Thanks |
Nova Scotia,
NS
Post Number: 12 Registered: Aug-04
| Posted on Sunday, October 03, 2004 - 07:26 pm: |
are the cards on PROG? or PLAY? check the jumper maybe. |
Post Number: 2 Registered: Oct-04
| Posted on Sunday, October 03, 2004 - 08:18 pm: |
I have 8 programers for atmega 128 No one works. Everytime gives me the same massege. FAILED TO ENTER PROGRAM MODE |
Nova Scotia
Post Number: 231 Registered: Jun-04
| Posted on Sunday, October 03, 2004 - 11:22 pm: |
Atmega Won’t Enter Program Mode: 1) Be sure it’s plugged in firmly and contacts are clean, a pink eraser is a good non-abrasive way to clean the oxidation off the contacts. 2) Have you programmed the card before on that computer? Yes skip to next step. No then check that jeepers is set to parallel port address 0x378 for LPT port1. Then you may want to try different port LPT port modes in the BIOS like ECP, EPP ECP+EPP etc. this has changes on the port communications as well as the voltage that is supplied to the port. Some PC's need to use a powered cable, like most laptop PC's have problems. No go, go to next step. 3) Rule out the cable; connect directly into the pc's parallel port. No go, go to next step. 4) If it’s a jumper type card try this: This is a little procedure that helps set these back to default. Try to get the lock/fuse bits to read if not follow the procedure below and try again: LOCK BITS - all checked FUSE LOW - All checked but BODEN and SUT0 FUSE HI - OCDEN, EESAVE, BOOTRST FUSE EXTENDED - both checked 1. Load up jeepers, and plug everything in for your Atmega as normal (i.e. Atmega in programmer, plug cable into computer) 2. make sure jumper is ON 3. Click the atmel tab, ATmega128, erase/flash eeprom 4. When it says erasing eeprom, PULL THE JUMPER 5. Do this 3 or more times 6. Then do Full Monty, when it says erasing eeprom, PULL THE JUMPER, and when it says writing, PUT THE JUMPER BACK ON 7. You will get errors, go back and repeat steps 3 to 6. You will notice that each time you do the full Monty, you will write a little more to the card before you get an error. 8. Eventually you will write the card, and you will be able to erase the eeprom WITHOUT PULLING THE JUMPER 9. Your Atmega is fixed. Always program at the correct frequency Some people had to do this 2~5 times others I have heard take up to 20 times. If all this fails either I missed a step that I don’t know of or assumed that you knew or your Atmega card is dead.
Post Number: 4 Registered: Oct-04
| Posted on Saturday, October 09, 2004 - 11:28 am: |
I NEED HELP I have a 3100 receiver. It was programmed for Belleview and I need it to convert to Dish. I found the keys and I FULL erase. Now I don't know how to program I plug in the Receiver and connected to Dish hoping that will download the program but NO LUCK> PLEASE SOMEONE HELP. J.K |
micro216 Unregistered guest |
| Posted on Saturday, October 09, 2004 - 05:09 pm: |
does that atmega 128 still work? a friend of mine bought one last winter and was never able to get it to work. probably couldnt find a good file to program it with and havin trouble finding someone that would explain it, especially how to set channel lineup |
Post Number: 5 Registered: Oct-04
| Posted on Saturday, October 09, 2004 - 08:09 pm: |
Dear members I have a 301 receiver. Originally it was programmed for Belleview and I re-programmed for Dish. Everything is O.K but I don’t get signal. The Satellite input is X X X X the transporter is X X X X I did the switch many times but the massage is no switch box detected. Do you have any suggestions how to over come this problem? Thanks
Nova Scotia
Post Number: 271 Registered: Jun-04
| Posted on Saturday, October 09, 2004 - 09:08 pm: |
jtag and erace SA3 to force the new firmware. |
Nova Scotia
Post Number: 272 Registered: Jun-04
| Posted on Saturday, October 09, 2004 - 09:10 pm: |
You will need a jeepers pfg for dishnet to program your atmega. |
| Posted on Monday, October 11, 2004 - 01:58 pm: |
I have Atmega128 working with the reciever 3000.It is working fine but,I can't get rid of "Err 005".Please help me out how I can fix it. |
New member Username: D77e80
| Posted on Wednesday, October 13, 2004 - 07:17 pm: |
Hello..I'm a newbie and Im about to work on my box so I can get all the programming...I have a lot of questions but I'm just gonna bother you with just one....Is it better the Atmega 128 or the REV Card....what's the diference? |
| Posted on Wednesday, October 13, 2004 - 09:05 pm: |
Angel revs dont work anymore go atmega128 works great and cheaper than those useless fta ird's that wont work in a couple of months cause the rom3 is shut down..charlie wants all fta's shut down as soon as possible. |
milesius Unregistered guest |
| Posted on Thursday, October 14, 2004 - 03:42 am: |
Hey FryGuy, thanks for the info. so which is it? ECP or EPP on the port settings? I am dead in the water and you are the first one that sounds like you are on to something. Posted on Wednesday, September 15, 2004 - 03:31 pm: -------------------------------------------------------------------------------- I doubt the problem had anything to do with the LPT port address being changed to the default 0x378 didn't have anything to do with your problem. You could have changed it to the port address you were useing in jeepers settings. The problems i have seen in the past was the port mode (ECP,EPP) one mode or the other will poser the card better and also having the inproper or a cheep cable. They male to male cables need to be pin for pin, some computer shops have the data cross-over cables that look similar. The cheep cables dont have all 25 conductors, printers only use 8-10 conductors and they don't bother put the others because they realy arn't needed. unfortunatly the few wires they don't include are needed for the programer to work. (I cant remember if it was a few power or ground wires or exactly what the pins were) The direst connection is the best way, cant get the wire any shorter to avoid power loss that for sure. Post feedback on my statement, it will help others with the same problem. |
Nova Scotia
Post Number: 289 Registered: Jun-04
| Posted on Thursday, October 14, 2004 - 09:21 am: |
Its a trial thing, I have found that on some computers one will work and on others the other or both will work just fine. It must be due to the parellel port chip type and brand. It hasn't been ironed out to a science yet and my not ever be figured out. |
| Posted on Thursday, October 14, 2004 - 11:42 pm: |
Thank you Atmega for your answer........ |
Post Number: 3 Registered: Oct-04
| Posted on Friday, October 15, 2004 - 02:51 pm: |
Hello everyone .......Can anybody help me....I have two questions.....I'm about to buy 3 boxes on ebay model dp301-013.....dp301-010 and a 311.....Can I work on them 3 so I can get all the programming ....are this 3 models goog?....And if they have a balance on them...Will this affect me somehow?......Hope you guys can help me.....thanks ...the rookie |
Nova Scotia
Post Number: 295 Registered: Jun-04
| Posted on Friday, October 15, 2004 - 11:36 pm: |
The 301-010 is a better model IMO but the 301-013 is almost exact for a few minor changes like the 301-010 don’t have a j-tag opening in the bottom you'll need to cut it out if you get one or build one in the back like I do (I'm always messing with the TSOP). The 311 is specific to dish I think so I would stick with the 301’s then you can go dish or bell express vu if you want to test that in the future. |
| Posted on Saturday, October 16, 2004 - 05:08 pm: |
Thanks Fryguy for your .......So I can test a box dish 311 with the Atmega 128.....Is that what your telling me......Does it has Jtag? |
Nova Scotia
Post Number: 298 Registered: Jun-04
| Posted on Saturday, October 16, 2004 - 07:18 pm: |
I dont know about the 311 on if it can be j-taged or not, but you would be better with the 301 so why bother with the 311? |
| Posted on Saturday, October 16, 2004 - 07:47 pm: |
Ok....The 301-013 it is........And what if they have balance on them will this affect me somehow?..... |
Nova Scotia
Post Number: 299 Registered: Jun-04
| Posted on Saturday, October 16, 2004 - 11:56 pm: |
Quote: "what if they have balance on them" What’s that mean? Do you mean that you’re worried about getting charged PPV with a second hand IRD? If they have PPV events in the memory still and you have an active account with it plugged in the phone line you could get charged for PPV you didn't watch. But I don't think they are that stupid at Dish Net or BEV. They know when the movie was running by a time stamp in the PPV memory and also who had the account at that time. So when the IRD calls home to report what PPV events were purchased it will get charged to the account holder at the time of the event, not you who just got the IRD and activated an account with them. If that has happened to anyone, please correct me. |
| Posted on Sunday, October 17, 2004 - 05:05 pm: |
hi guy's u c tis is my first time doin tis.. and i m havin a problem when i enter my ird# and box key.. and then i press full monty. get a failed box appears why is tat?? also what the difference between Version 2.1.0 (Build 016)TCFD11-Fusion-oct 1st w_PPV tat's one but then i also have Version 2.1.0 (Build 016) |
| Posted on Sunday, October 17, 2004 - 06:06 pm: |
My dish is down. Is there anybody that knows where can i download the new program, i already have jeepersdx thanks |
| Posted on Monday, November 08, 2004 - 08:15 pm: |
after successful programming of my atmega 128 with jeepers when I insert the card into the receiver I get message "error 19 the smart card is not inserted properly". I have reprogramed many times but still the same result. can anyone offer suggestions? |
Nova Scotia
Post Number: 328 Registered: Jun-04
| Posted on Tuesday, November 09, 2004 - 02:51 am: |
First double check your #'s (IRD, CAM, box keys and keys), also be sure that you have a valid ROM3 CAM ID if not generate with scamers2 (Your CAM ID with your original card won’t work, if it does it won’t for long). If you have done all that and are sure there are no errors. In jeepers select "verify Program" to be sure that jeepers is writing properly and that the images match what it is suppose to be on the card. If that fails try these next steps. Check that the lock/fuse bits are being set properly before and after writing and if it’s a card with a jumper be sure it’s removed on in the run position. If the contacts are dull looking, clean with a pink eraser.
| Posted on Tuesday, November 16, 2004 - 06:15 am: |
Hi All I have an Atmega128, I do not have a programer for it. I would like to know.. will ISO Loader can be used to program Atmega or its a separate loader.Secondly what are the other hardware required and how much its going to cost me. So please advise me the list of the hardware/software required to program Atmega from scratch as i do not have the box keys also.And the reciever is a Bell Express view reciever. Thanks Shakeel
Nova Scotia
Post Number: 334 Registered: Jun-04
| Posted on Tuesday, November 16, 2004 - 04:03 pm: |
A loader wont work its a simple parallel port programmer without a crystal. 1) Atmega parallel port programmer. ($20-25 CND) 2) Jeepers to program the card. (Free download) 3) You will need j-tag to get the box keys and to Backup your TSOP. ($60-70 CND) 4) a program called j-keys to get the box keys and to do the backup of the TSOP. (Free download) 5) A D-lock to prevent the TSOP from being written to by an ECM (not necessary if you don’t mind using a j-tag to write back your TSOP each time its hit) ($42-50 CND) That’s the tools that you will need to do it all with the Atmega128 card.
| Posted on Wednesday, November 17, 2004 - 10:46 pm: |
Few Questions. I am also a newbie interested in this 'hobby'. I have a Dish PVR 508 receiver, will the Atmega work with this? Also, what is a TSOP? Thanks for your help. |
Bobby E. Unregistered guest |
| Posted on Wednesday, November 17, 2004 - 10:54 pm: |
I also want to know whats a TSOP. Thanks |
| Posted on Wednesday, November 17, 2004 - 11:15 pm: |
Also.. can I take a friend's card which has a paid subscription and copy it to another receiver using the atmega or something similar? |
Nova Scotia
Post Number: 337 Registered: Jun-04
| Posted on Wednesday, November 17, 2004 - 11:50 pm: |
TSOP = Thin Small Outline Package Its the form factor (shape) of the memory chip that stores the receivers firmware (software that’s built in an hardware device). The TSOP has the software that allows the receiver to function, on power up it "boots up" like a computer would. That’s why its important to back it up and get failure with a j-tag and the program j-keys. The boxkeys, IRD # is stored on the TSOP also.
Nova Scotia
Post Number: 338 Registered: Jun-04
| Posted on Thursday, November 18, 2004 - 12:00 am: |
mixx, no you cant copy a subscription over to another card. If you have an Atmega or similar card they can get the programming anyway. Paying for the programming that you use is the right way to do it and stay legal when you are playing around with testing. Moving a CAM from one receiver to another can be done but requires a bit of work to change the numbers on either the CAM or the receiver. This is because the CAM is married to the receiver and is not suppose to be easily moved to other receivers. |
| Posted on Thursday, November 18, 2004 - 06:52 am: |
Have an atmega card testing dishnet every 10 or so min get an error 151 and have to reset the receiver. Anyone know why? |
Nova Scotia
Post Number: 340 Registered: Jun-04
| Posted on Thursday, November 18, 2004 - 02:50 pm: |
I'm not testing dish right now but it sounds like an ECM or your PFG file for the atmega is out of date. |
| Posted on Friday, November 19, 2004 - 08:10 am: |
Not the atmega prg still get error 151 every 5 min after rebooting has anyone heard of this problem |
| Posted on Friday, November 19, 2004 - 03:09 pm: |
thanks for the Info FryGuy.ca.. I would like to know is there a way I can build this Atmega parallel port programmer. Regards
Nova Scotia
Post Number: 343 Registered: Jun-04
| Posted on Saturday, November 20, 2004 - 01:37 am: |
Yes you can. I have the board layout and schematics for the Atmega card and programmer on my ftp server at ftp://fryguy.ca/public_files/Guides-Information/Mini_Dish_Hacking/BEV/ with many other files. Feel free to upload any files or guides that you have to the "upload_here" folder. |
| Posted on Saturday, November 20, 2004 - 08:30 pm: |
I have the Dish PVR508 receiver. Do you know where the JTAG port on it would be? i didnt see anything on the back or bottom of the receiver, so I'm assuming i'm going to have to take the unit apart to get to it? Thanks |
Jaguar Leo Unregistered guest |
| Posted on Sunday, November 21, 2004 - 05:10 am: |
Hello Everyone I would like to know why the NFL and TSN-S channels don't come in (stay black) on my Atmega 128 card. Mostly everything else does. For new BEV 3100 receiver and the 128.
Nova Scotia
Post Number: 348 Registered: Jun-04
| Posted on Sunday, November 21, 2004 - 12:56 pm: |
It could be your Tier settings but thats not the case, those channels are nagra2 and thats why you need the new card. The soloution is to Pay for the programing you watch so you can get the new card. There is no nagra2 hack yet (that I know of anyway). |
| Posted on Sunday, November 21, 2004 - 01:39 pm: |
Hi FryGuy, Thanks for the ftp link but i couldnt find the file which shows the methods or steps to build my own atmega programmer. Please advise
Jeff Brod Unregistered guest |
| Posted on Sunday, November 21, 2004 - 06:42 pm: |
Anyone tell me how to get rid of the 153 error using atmega card with dishnet. After erasing S5 3 times I am good for 30 mins or so then its back Help |
| Posted on Sunday, November 21, 2004 - 09:19 pm: |
Hi, I have just got a receiver and the ATMEGA128 Card. Can you please tell me what do I need to reprogram the card, or give me an address for beginners to learn how to do that Thanx folks |
Nova Scotia
Post Number: 349 Registered: Jun-04
| Posted on Sunday, November 21, 2004 - 10:51 pm: |
Jeff Brod, If your getting ECM'ed check that your using a valid ROM3 CAM #. |
Nova Scotia
Post Number: 350 Registered: Jun-04
| Posted on Sunday, November 21, 2004 - 11:01 pm: |
Fuzzyy, I have files on my public ftp at ftp://fryguy.ca/Public_Files/Guides-Information/Mini_Dish_Hacking/ there is a complete listing of every file and guide that you'll ned and more. www.sattech.ca, this site and many more have chat forums for all the help that you need. |
Nova Scotia
Post Number: 351 Registered: Jun-04
| Posted on Sunday, November 21, 2004 - 11:04 pm: |
The link to the programer and Atmega schematic is at ftp://fryguy.ca/Public_Files/Guides-Information/Mini_Dish_Hacking/BEV/Schematics / The file is "Full_Board_Layouts_For_Atmega128.ace" Direct link is ftp://fryguy.ca/Public_Files/Guides-Information/Mini_Dish_Hacking/BEV/Schematics /Full_Board_Layouts_For_Atmega128.ace |
| Posted on Sunday, November 21, 2004 - 11:53 pm: |
Thanks for all this Info and your time FryGuy. I read the file.. its kinda complicated for me... but I wanna know which wire to connect to which pin of Db25 .. See I have the atmega card which has few pins on it .. I know the programmer has a female jack in which these pins go... and then on the other end there is a Db 25 jack.but I wanna know the pin to pin connection so that I can make a simple connection wire to connect pins on the card to Db pins directly
| Posted on Monday, November 22, 2004 - 06:57 am: |
Thanks FryGuy How do I check to see if my cam number is valid I am new to this |
Nova Scotia
Post Number: 353 Registered: Jun-04
| Posted on Monday, November 22, 2004 - 07:31 pm: |
Thats easy, just don't use the CAM ID of your plastic CAM because thats most likely a ROM 10/11 ID so you need to generate a ROM3 CAM ID with scammers2 a CAM ID generator. |
| Posted on Wednesday, November 24, 2004 - 11:41 pm: |
Hi FryGuy, I would like to know .. Does 'Dish Pro 322 receiver' has a Jtag or not???
Nova Scotia
Post Number: 362 Registered: Jun-04
| Posted on Friday, November 26, 2004 - 06:25 pm: |
Have no idea, I have never dealt with one before. |
| Posted on Monday, November 29, 2004 - 10:35 pm: |
I am interested in Buying Atmega card. If any one wants to sell please let me know Thanks Shakeel |
Nova Scotia
Post Number: 373 Registered: Jun-04
| Posted on Tuesday, November 30, 2004 - 10:45 pm: |
http://fryguy.ca/ |
pkilfoyl Unregistered guest |
| Posted on Wednesday, December 01, 2004 - 10:26 am: |
is there a limit of how many time you can re-write a atmega128 card??? How many time can I do it before it dies?? pkilfoyl@hotmail.com
Nova Scotia
Post Number: 376 Registered: Jun-04
| Posted on Wednesday, December 01, 2004 - 01:21 pm: |
There is a limit to writes but its so high that its not likely you'll reach it. Its aprox 10,000 writes for the flash ROM and 100,000 writes for the EEPROM. The chip is most likely to die from being ran over clocked before you cant write to the card. (Atmega max is 16 MHZ but they have pushed to over 20 MHZ) |
Nova Scotia
Post Number: 377 Registered: Jun-04
| Posted on Wednesday, December 01, 2004 - 02:36 pm: |
| Posted on Friday, December 03, 2004 - 06:55 pm: |
the paticular atmega I have had jumpers on it that broke off. Can anyone point me into the right direction as to repairing/finding new jumpers?? |
Nova Scotia
Post Number: 381 Registered: Jun-04
| Posted on Saturday, December 04, 2004 - 12:47 am: |
Ordering just one header isn’t worth the cost of shipping. I would use a soldering iron and remove the old pins (Don’t apply too much heat or you'll lift a trace or an via hole) and replace them with some old resistor leads clippings (They are stronger) or small solid copper wire. |
| Posted on Thursday, December 09, 2004 - 12:44 pm: |
I'm trying to program my atmega card. can someone tell me wheres the jumper |
Nova Scotia
Post Number: 397 Registered: Jun-04
| Posted on Saturday, December 11, 2004 - 11:48 pm: |
It may not have a jumper at all, not all of them have a jumper. |
Nova Scotia
Post Number: 399 Registered: Jun-04
| Posted on Sunday, December 12, 2004 - 02:17 am: |
This is exactly the type of sh*t that pisses people off when they visit a forum! |
| Posted on Sunday, December 12, 2004 - 02:45 pm: |
What sh*it ? He just wants to know, man. Youre mean. |
Leslie Kane Unregistered guest |
| Posted on Sunday, December 12, 2004 - 03:42 pm: |
Gentlemen, there's no need to be so rude. Not everyone can be a "know it all". We are here to learn and help each other. Thank you. |
Nova Scotia
Post Number: 401 Registered: Jun-04
| Posted on Sunday, December 12, 2004 - 11:36 pm: |
Its a misunderstanding. You all missed the previous post that was removed by the administrator. I notified the adimistrator of the adult graphical content (Male/homose*ual in nature) that was posted by a user. It was all removed, but my posting after the content was not. The posting with the adult content was by a user claiming to be a DSS dealer (with a web site and all)and has been spaming products on the forums and posting adult material. |
| Posted on Monday, December 13, 2004 - 02:40 pm: |
Sorry about that. I didn't see the filthy post you mentioned. And thanks for helping keep this a decent and informative thread. You are a good man. Thanks again and Happy Holidays. |
| Posted on Tuesday, December 14, 2004 - 01:44 am: |
sorry, dude |
Nova Scotia
Post Number: 429 Registered: Jun-04
| Posted on Tuesday, December 14, 2004 - 06:22 pm: |
The admin missed my comment to that user, but after I had posted I decided to report it because it’s nature. I have no idea how many younger teens/youths use this forum and I’m sure they wouldn’t want to see the content that was posted nor would their parents. Again it was a misunderstanding and I’ve been called worse things before.
largo key Unregistered guest |
| Posted on Sunday, January 02, 2005 - 10:24 am: |
Create a jeepers folder and put your jeepers in that folder and download any working pfg dish or bev whatever you are testing in the same folder. then open jeepers and click file on the top left corner of jeepers. then click prferences then browse and look for the jeepers folder that you created and click ok. close jeepers and when you open it again you should be fine. THIS IS HOW TO PROGRAM THE ATMEGA select the program (current that's posted) download it in the atmega file section -select the network… which is BEV or DISH - make sure you choose the wright board…. 18.00000mgz, 18.43200, etc (it is indicated on your atmega) - press GET “keys””aux 0, aux 1, should have keys in them) -Your ird # = R 00 1234 5678 –XX (fill your ird # with your info) -Your cam id= S 04 1234 5678 – XX (fill your cam ID with your info) (smart card) -PUT your box keys -choose your time zone -zip code = like 2004 for EST (pick from the time zone list) -don't touch the min and max tier unless adjustments are needed… (make sure (if you have one) that the jumper is set on program) PRESS FULL MONTY (wait till it finishes) (make sure (if you have one) that the jumper is set on play… “or if you don’t have the option to switch from program to play then it probably has to be removed (unless it's a jumperless card)) PUT YOUR ATMEGA and since the keys are already in, then it will work right away since the keys donnot have to autoroll AND if you followed all these steps… VOILA your are now watching SATTELITE!! |
New member Username: Dlap4453
Post Number: 1 Registered: Jan-05
| Posted on Monday, January 03, 2005 - 06:48 pm: |
Where can I get the latest jeepers and Nawapo programs for my atmega 128 card? Thanks |
Nova Scotia
Post Number: 491 Registered: Jun-04
| Posted on Tuesday, January 04, 2005 - 07:42 am: |
Here is the latest working jeepers .pfg no searching required. :-D |
Nova Scotia
Post Number: 492 Registered: Jun-04
| Posted on Tuesday, January 04, 2005 - 07:44 am: |
Nova Scotia
Post Number: 493 Registered: Jun-04
| Posted on Tuesday, January 04, 2005 - 07:54 am: |
Latest Jeepers and configuration files. (part on of a spaned zip file, upload is limited to 100k) |
Nova Scotia
| Posted on Tuesday, January 04, 2005 - 07:55 am: |
Nova Scotia
Post Number: 494 Registered: Jun-04
| Posted on Tuesday, January 04, 2005 - 07:56 am: |
Jeepers_and_config.zip part 2
Nova Scotia
Post Number: 495 Registered: Jun-04
| Posted on Tuesday, January 04, 2005 - 07:57 am: |
Here is a handy tool for generating a valid CAM ID number if you dont have one.
New member Username: Dropik
| Posted on Friday, January 21, 2005 - 12:04 am: |
so many guys have a problem with programming Atmega 128, and it looks like the main problem is powering this device. ;\ Anybody knows how to plug in external power to atmega ( easiest way ?) can i use power from my computer ? I know i need 5 V. Please help . |
Nova Scotia
Post Number: 548 Registered: Jun-04
| Posted on Friday, January 21, 2005 - 12:53 am: |
I use a modified parallel port cable (DB-25 male-female) that has a pig-tail of a PS2 plug wired on it to get power from the PS2 port for power. Just look up the pin-outs of the PS2 plug and find the power points on the DB-25, I recommend using diodes to isolate the two voltage lines just watch the polarity of the diodes. |
Post Number: 2 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 11:02 am: |
I'll try it. Thanks a lot Fry Guy. |
Post Number: 3 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 11:41 am: |
where did YOu get this cable from ?or Did You make it ? I know it's possible to buy all Atmega kit with DB25 w/ps2 cable but i dont know where . Maybe YOu know . |
Silver Member Username: Knee_grow®
Detroit
Post Number: 155 Registered: Jan-05
| Posted on Friday, January 21, 2005 - 02:16 pm: |
Often imitaded, never duplicated. |
jeffrok Unregistered guest |
| Posted on Saturday, January 22, 2005 - 09:00 pm: |
i only get a black screen after using the latest keys does anybody has any idea how to fix this |
| Posted on Thursday, February 03, 2005 - 08:13 pm: |
ATMEGA TROUBLE-SHOOTING ================ 1. "Failed to Enter program mode" Message from JeepersDx210 1. ATMEGA128 Connection: 1.1 Verify the card is inserted into programmer correctly. 1.2 Insert the ATMEGA128 with a Smart Card or business cards in programmer. 1.3 Verify ATMEGA is rectangular, no external bits attached to board. 2. Voltage Problem: 2.1 Try using a gender changer instead of a cable for the programmer. 2.2 Try using a different computer ( no Compaq's, Dell's, HP's these are known to cause problems ). If works create a external power supply for programmer. 3. Incorrect Jumper(Black ATMEGA) or Switch(Blue ATMEGA) Setting: 3.1 For Black ATMEGA program with Jumper ON. 3.2 For Blue ATMEGA program with switch away from ATMEGA128 chip. 4. ATMEGA Programmed at improper crystal frequency. This is bad as it may render the ATMEGA128 chip useless until unlocked. 4.1 Verify the crystal frequency by looking at the silver item on the ATMEGA board and verify that are your using the correct board type ( i.e.; ATmega128@##.####MHz). 4.2 See 5.1 5. ATMEGA128 Locked 5.1 Start JeepersDx and select ATMEL -> ATmega128 Erase Flash/EEPROM, then program at proper board frequency of crystal. If no go, look into 1.2 more. Please note: This requires a known computer that can write and ATMEGA board. 6. "Smart Card not inserted Correctly Message" when ATMEGA in receiver. 6.1 Incorrect Programming: 6.2 Verify you set Board type as ATmega128 @ 18.0000MHz for Black ATMEGA and ATMEGA @ 18.4320MHz for Blue ATMEGA. 6.3 Jumper or Switch in Wrong Position: 6.4 Make sure jumper is off on Black ATMEGA while in Receiver. 6.5 Make sure switch is towards ATMEGA128 chip on Blue ATMEGA's. 7. Capacitors Blown: 7.1 Remove C1 and C2 from ATMEGA board, reprogram and see if works. 7.2 Preview Channels Only, All others Black Screen. 7.3 Initial Wait for video: 7.4 Can take from 20 seconds to 2 minutes for initial video to appear upon power on of receiver. 8. Wrong Keys 8.1 Verify Key0 and Key1 are correct. 8.2 Verify proper boxkeys are being used. 8.3 Static 8.4 Program ATMEGA as normal, then insert in IRD for 5 minutes trying to watch a black channel. Then connect ATMEGA back to computer, and Hit Actions -> Verify EEPROM, then Actions -> Verify Program. 8.5 If errors: Reprogram ATMEGA, unplug power from IRD and satellite feed, insert ATMEGA, wait 1 minute, then plug in power and satellite feed. 8.6 If no errors: Reprogram ATMEGA, select ATMEL -> ATmega128 and Lock/Fuse Settings, select yes to continue, remove check mark from M103C in Fuse Extended section, then remove jumper(black ATMEGA) or move switch(blue ATMEGA) towards ATMEGA128 chip, then hit write. 9. Bad ATMEGA128 chip 9.1 Program ATMEGA as normal, and Hit Actions -> Verify EEPROM, then Actions -> Verify Program. If error and you have tried on many different computers, most likely bad chip. 10. Picture will freeze in few min to few hours. 10.1. Wrong Lock/Fuse bit. 10.2 Up/down channel will work again. 10.3 *** Don't fool with other setting, do this at your own risk*** Remove jumper from Black ATMEGA or move switch towards ATMEGA128 chip on Blue ATMEGA. After program ATMEGA as normal, select ->Atmel,->Atmeg128-> lock/fuse settings. Click on "CKOPT" to de-select. Click on write 11. Incorrect crystal used on ATMEGA. 11.1 Verify you are using either a 18mhz or 18.43mhz crystal on ATMEGA. 12. ATMEGA programmed at board type ATMEGA128 only. 12.1 Program at proper crystal frequency and verify switch(Blue ATMEGA) is towards ATMEGA128 chip or Jumper(Black ATMEGA) is off. 12.2. Software catching up 12.3 Blackouts occur when the stream is out of whack with the software and the software needs to catch up with the proper sequence of stream, usually can take up to 45 seconds. 13. Video for few minutes/hours/day then black screen. 13.1 Programmed at incorrect crystal frequency: 13.2 Program at proper crystal speed ( see 2.1.1 ) 13.3 Keys change: 13.4 Program ATMEGA with new keys: Connect ATMEGA to computer, start JeepersDX, hit get under keys section, then hit write. Insert ATMEGA back into receiver. 14. "Blacked out in the area" message while trying to watch a channel. 14.1 Wrong blackout string 14.2 Use default blackout string of "00 00 B4 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F". 14.3 Channel guide: 14.4 Do not use channel guide to get into channel, type in channel # directly, if still same message press channel up then channel down. 15. Channels Missing in guide. 15.1. Wrong tiers: 15.2 Use default tier settings from JeepersDX210.After program ATMEGA as normal, select - >Atmel,->Atmeg128-> lock/fuse
| Posted on Friday, February 04, 2005 - 03:21 pm: |
where can i find the equipment to program the atmega 128 and how do i go about programing it I'm new at this so if anyone can help and give me an orientation |
| Posted on Friday, February 04, 2005 - 05:17 pm: |
READ these forums and other forums,so thats your orientation..look in the yellow pages for "atmega"..maybe your local dealer can sell U the equipment and orientate you...LOL |
| Posted on Saturday, February 05, 2005 - 01:33 pm: |
im sorry to have come across some know it alls some of us are purely sophomores when it comes to these things |
| Posted on Saturday, February 05, 2005 - 03:12 pm: |
If U read this entire thread,it tells U how to program and trouble shoot the atmega...and site links are here to buy the necessary hardware..U just need to READ.. |
| Posted on Saturday, February 05, 2005 - 07:10 pm: |
a place to buy..one of hundreds.. http://dsshideaway.com/dish.html |
still a newbie Unregistered guest |
| Posted on Sunday, February 06, 2005 - 12:11 am: |
Help, picture froze but guide still worked, tried reprograming atmega 128, currently receiving music channels, interactive channel, information channels and guide, all other channels are blacked out. Can anyone help me? |
| Posted on Sunday, February 06, 2005 - 12:22 am: |
I did follow the troubleshooting step 8 for the atmega 128 still only receiving black screen for all regular channels and all channels say they are purchased. |
yzrider088 Unregistered guest |
| Posted on Monday, February 07, 2005 - 05:16 pm: |
K you guys need to stop asking stupid questions about getting started....I'm 16 and i got a receiver with programmed card that i did myself and it all works 100% with PPV, if im 16 and can do it, YOU CAN TOO. http://www.dishnewbies.com/ If this site does not help, then you are too much of a n00b to do DSS Hacking and you should quit now. Good retailers are DSSPIMP.com and DSSStuff.ca Peace out fools, good luck with latest ECM |
New member Username: Webspyder
Inman,
SC
Post Number: 1 Registered: Feb-05
| Posted on Tuesday, February 08, 2005 - 09:27 pm: |
I am having difficulties with extracting box keys from my new JVC 6000 dish network receicer.I unplug the box, line up the pogo a ground pins, touch to the appropriate solder points in the jtag port, and plug the box in. As soon as it receives power,the receiver emits a high pitched squeel! I attempt to power on the box, but it does not respond. I turn on JKEYS and check the settings, then hit detect. Nothing happens! I am chasing my tail here! Anyone with experience? I could use some help! |
New member Username: Filtrate
| Posted on Wednesday, February 09, 2005 - 07:47 am: |
Hi, I have a bell 3100 receiver, what did i need to get it going... Atmega 128 wafer ??? tell me what i need to buy.. please someone... thanks... or is the atmega 128 auto-roll wafer all i need please e-mail me with some help.. winsor_adam@hotmail.com |
Inman,
SC
Post Number: 3 Registered: Feb-05
| Posted on Tuesday, February 15, 2005 - 09:43 pm: |
I have successfully jtaged my box, and programmed my atmega 128. When I power on the IRD w/ the programmed atmega in the slot,all of my channels are blacked out! I can see what's on, but get no video or sound. Any thoughts?
Nova Scotia
Post Number: 589 Registered: Jun-04
| Posted on Tuesday, February 15, 2005 - 10:57 pm: |
Double check all your numbers and lock/fuse settings. |
Inman,
SC
Post Number: 5 Registered: Feb-05
| Posted on Monday, February 21, 2005 - 09:59 pm: |
Thanks a bunch fryguy! My 2700 is up and running, just had to change some settings in BIOS. The support crew where I purchased my gear refuse to help me 2 all! I am thinking of purchasing another receiver, as I have been unable to jtag my HD 6000. Do you know of any problems w/ jtagging or programming the 501 model w/ PVR? |
Nova Scotia
Post Number: 605 Registered: Jun-04
| Posted on Tuesday, February 22, 2005 - 01:42 am: |
Glad you got it fixed. It's amazing that the vendor didn't at least try to help you out. I can't help you with the 501, I've never played with that model. I haven't had much time to play around with any new toys :-( . |
New member Username: Dishstream
| Posted on Wednesday, February 23, 2005 - 05:39 pm: |
HI; I am getting the same thing with my atmega 18.0, few channels like 101, 213, 262 on 119 and other other blackout. uptill now I have not got any helpfull hints from other forums too, If you find the solution please post it, I will too. |
| Posted on Saturday, February 26, 2005 - 02:28 am: |
www.dssftp.com/forums/index.php best forums i have found |
Inman,
SC
Post Number: 6 Registered: Feb-05
| Posted on Sunday, March 06, 2005 - 08:13 pm: |
I am trying to jtag a 301-13 duel tsop receiver. I have removed the board, and have made multiple attempts. I have changed settings in BIOS beetween attemts( EPP, ECP, ECP+EPP,NORMAL ). This usually works on stubborn receivers, but this one is just laughing @ me. Anyone had experience with this model? I would appretiate any help. |
| Posted on Sunday, March 06, 2005 - 09:02 pm: |
There are a couple files about the 301-13 (top jtag and vidmod) at www.dsscommunity.com README file share area |
