Thread: Vhs to Dvd copy problem |
New member Username: Murrfy
Post Number: 1 Registered: Oct-04
| Posted on Wednesday, October 06, 2004 - 08:15 am: |
ANY ONE GETTING PAST THE MESSAGE THIS VHS IS COPY PROTECTED CAN NOT BE COPYED. IS THERE A WAY? IAM USING AN EMERSON VHS AND DVD RECORDER COMBO. I AM SURE THERE IS SOMEONE THAT IS SMARTER THAN ME OUT THERE THANKS MURRFY |
Silver Member Username: Samijubal
Post Number: 286 Registered: Jul-04
| Posted on Wednesday, October 06, 2004 - 09:14 am: |
You need a stabilizer. |
Unregistered guest |
| Posted on Thursday, October 07, 2004 - 07:01 pm: |
i`m looking for a good recorder to transfer my old vhs movies to dvds. can you tell me a good brand to get, and how it works. thank you very much.. |
Post Number: 289 Registered: Jul-04
| Posted on Friday, October 08, 2004 - 12:24 am: |
The JVC records pretty clean from videotapes, but the contrast and brightness aren't as good as the originals. A DVD recorder works just like a VCR basically, except it has many more options than a VCR. |
