Home > Message Board > Home Video > Rear Projection TVs > Archive through October 23, 2004 > Burn in and hdtv programing
Author Thread: Burn in and hdtv programing
Username: Chiathomas
on a widescreen set will my regular tv shows have black bars on side? I have regular directv will my reception be worse on a widescreen? Is burn out a problem? Is there a tv that you can see from the sides? I have a philips 60in 8yrs old have never been happy with it. I need one that has a good picture on regular tv do not watch dvd. If I get one with progressive scan will I need a dvd player? What does a dvd player have to do with a tv? Money IS an object!!!!!!
xvxvxvx
on a widescreen set will my regular tv shows have black bars on side? ---Yes
I have regular directv will my reception be worse on a widescreen? ---No since you are already used to a 60" picture
Is burn out a problem? ---Do you mean burn-in? Only on a rear projection CRT or Plasma display. Bulbs eventually burn-out such as those in an LCD or DLP display.
Is there a tv that you can see from the sides? ---How far to the sides?
I have a philips 60in 8yrs old have never been happy with it. ---Then you will likely not be happy with a new widescreen either.
I need one that has a good picture on regular tv do not watch dvd. ---The smaller the screen the better SD tv looks.
If I get one with progressive scan will I need a dvd player? ---Only if you watch DVD;s since you don't then no.
What does a dvd player have to do with a tv?--- Nothing at all if you do not watch them.
Money IS an object!!!!!! ---You should have married for money and not love.
xvxvxvx
Home > Message Board > Home Video > Rear Projection TVs > Archive through October 23, 2004 > Burn in and hdtv programing [ « Previous ] [ Next » ]
