Home > Message Board > Home Video > Rear Projection TVs > Archive through October 23, 2004 > Toshiba 65H14 vs. 65H84
Author Thread: Toshiba 65H14 vs. 65H84
Does anyone know any major difference between these two models? Costco's selling the 65H14 for $1999 (in-store) and the 65H84 online for the same price. I can only see some minor differences between the two on Toshiba's site, but I need to know the dirt. I have the 65H84 on pre-order and am afraid it doesn't have the wide 160-degree viewing angle that the 65H14 claims. Does the H84 have a shinier reflective coating than the H14? Any help would be greatly appreciated.
Username: Newbie88
Ottawa, Ontario
Just some info (hopefully a little bit helpful!)Currently, here in Canada, they only stock/sell the 65H84 as it is the newer model. There is also a 65HX83 (Cinema Series) 65HX93 (Cinema Series Pro).
Just to add to the confusion, have you looked at the Hitachi 65X500 (Directors Series). Worth a look even if just to compare features.
Hey, any bit of info helps. I wasn't even sure which model was newer. Thanks for the reply.
Anyone else have some opinions or experience with either model?
Home > Message Board > Home Video > Rear Projection TVs > Archive through October 23, 2004 > Toshiba 65H14 vs. 65H84 [ « Previous ] [ Next » ]
