Thread: Need p4 & p5 card reader |
New member Username: Satanluvsme
Post Number: 1 Registered: Sep-04
| Posted on Friday, September 24, 2004 - 10:32 am: |
does anyone know where i can get a card reader? |
applebee Unregistered guest |
| Posted on Friday, September 24, 2004 - 12:00 pm: |
isn't one yet..a "card reader" is a combination of hardware and software..and NO confirmed hardware works for the P4/5 yet,EXCEPT using your old HU loader flashed to UL4S and using winexplorer software file P4-D1 card checker UL4S v3.zip...this will ONLY do a PARTIAL read of the card,nothing else works at this point in time...U need to wait until there is a true stable P4/5 hack released to know what hardware and software is really going to be needed..RUMORS are that a simple iso programmer,winexplorer scripts,and BasicH program might be all that are necessary...time will tell. |
New member Username: Bluejames2003
| Posted on Friday, September 24, 2004 - 09:39 pm: |
I bought 2 p5 cards on line that are guaranteed to get the preveiw channels..is there something speciasl I must do or did I get scammed. |
| Posted on Friday, September 24, 2004 - 10:15 pm: |
any/all P4/5 card will get the preview channels!..but thats all U'll get now,until the P4/5 hack is released and made public..then U'll have to program them.. |
Finish 24 Unregistered guest |
| Posted on Saturday, September 25, 2004 - 12:31 pm: |
I can get them programmed them for U ---Just send me $50 bucks /ea. details here.... finish24@aol.com |
Silver Member Username: Jmill1948
Chester,
Va
Usa
Post Number: 287 Registered: Apr-04
| Posted on Saturday, September 25, 2004 - 06:20 pm: |
here you go............. Top View $22.99 Usually Ships: 24 hours -------------------------------------------------------------------------------- Product Specifications: Protocols: T=0, T=1 ISO Rating: ISO-7816 (Parts 1/2/3) Clock Frequencies: 1.2288MHz / 3.57945MHz / 3.6864MHz / 4.608MHz / 9.216MHz / 18.432MHz Interfaces: RS-232 DB-9 Power Input: +7.2 to +24VDC @ 200mA Dimensions: 3.5" x 2.5" x 0.5" Power/Mode/Data Flow Indications: (6) Multicolored SMT LED's O/S Supported: Any O/S that supports the RS-232 Standard Included Accessories: (1) 6' DB9 Computer Interface Cable (1) 117VAC/9VDC 300mA Wall Adapter (4) 3M® Insulated Bump-on Rubber Feet (Installed) -------------------------------------------------------------------------------- Model: SKU 3441 ●Shipping: Free Shipping Compare at: $280.99 Our price: $269.99 Product Details: This loader we assume that soon,will be the Unit to P4-P5 card, We are in Test. If you have any Questions please e-mail us True universal ISO-7816 - 1/2/3 compatibility On board hardware based universal smart card reader/writer Microsoft® PC/SC compatible (USCT PC/SC Driver Required) . On board universal smart card diagnostic and recovery system On board Atmel AT90S2313-10PI Micro-controller For P4-P5 card Test AT90S8515-10PI. On board (ICP) Atmel programming interface. Will gain entry to cards previously untouchable by *old* code Future Unlock updates for Unlocking future Dealer Lock down 3M scripts One unit, one mode, does it all without any re-flashing. Provides the solution for cards that won't open with existing loaders and programming. Repairs otherwise un-glitchable card. One switch mode selection. All matched and hand selected device components No hardware device drivers needed in direct RS-232 mode Supports all speeds of serial communication up to 115,000 baud Compatible with all MCU smart cards and most Memory Only cards Compatible with all RS-232 smart card development software Supports both commercial and military power specifications Only true hardware based universal all-in-one S-C terminal available Amphenol "snap-in" card slot rated at 200K+ insertions Incorporates the exclusive and convenient SDLOGIC ON/OFF switch Incorporates a 20-pin dip socket for easy removal of Atmel chip Incorporates a 4 position switch selector for modifiable timing slopes Incorporates the proven SDLOGIC INTERSIL RS232 Chip Incorporates a new heavy duty DC jack Incorporates a new surface mount heavy duty voltage regulator Incorporates (5) separate Philips74Hc4053N Separate mode indicators Atmel Pin 1 Jumper Enable/Disable /Bridge. Enhanced high-speed buffer circuitry support (Jumper Enable/Disable) New anti-static/chemical coating treatment to the Amphenol card slots -------------------------------------------------------------------------------- |
| Posted on Saturday, September 25, 2004 - 06:37 pm: |
BIG SCAM |
Chester,
Va
Usa
Post Number: 297 Registered: Apr-04
| Posted on Saturday, September 25, 2004 - 06:39 pm: |
you think so? |
| Posted on Saturday, September 25, 2004 - 08:57 pm: |
IM 100% POSITIVE
| Posted on Saturday, September 25, 2004 - 08:58 pm: |
IM 100% POSITIVE |
