Thread: 110-119 sats |
| Posted on Wednesday, September 22, 2004 - 06:06 pm: |
Hello I got sat 119 fine, good reception How do I get 110 ??? when I look for 119 all is fine then I go and put mark in 110 and it tells me wrong echostar 119 satelite and its red I put the mark on 110, when I leave receiver to try set sat up ,it stops and comes back to setup menu.. confused How can I get both 119 and 110 Have a dish 500 a switch 021, two lnb's and one receiver Appreciate the help I am limited on just one satelite I thought as long as I have the switch 021, two lnb's and one receiver I should be able to get both 110 and 119 Thanks for a reply A
| Posted on Wednesday, September 22, 2004 - 06:51 pm: |
If you have aimed correctly then hook up each lnb by itself and you should get both then put your switch on. You might have the wrong sat on the wrong port also, switch the 2 cables try again...later |
New member Username: Blasterboyman
Post Number: 1 Registered: Aug-04
| Posted on Wednesday, September 22, 2004 - 11:15 pm: |
could some please email pansat up date i bourght 3 pansat receivers and cannot get any programm my email blasterboyman@hotmail.com |
