Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2004 > Programmers and Cards
Author Thread: Programmers and Cards
Username: Thomas2341
I program my card every week. I never thought about getting into the buisness of selling programmers or programmed cards but it seems safe over the internet. I have these for sale and if you are intrested email me @ ChrissMcGuiree@yahoo.com
Finish 24
I also have the same shít... BUT CHEAPER !!
INTERESTED : finish24@aol.com
Username: Jmill1948
Chester, Va
Usa
Post Number: 260
s.o.s. peace.........jmill
sathouse.com.pa has act
www.sathouse.com.pa has a activation for you dudes...swing by the site and check out the site is free to join and look for yourself many satisfied customers ..Free DAVE tv again.
jojo49
there is nothing free, you pay for it one way or the othere
I have two P# Sat cards I am looking for a Test card for my sat system in exchange.
diverX234@yahoo.com
be quiet
jojo49.aka.applebee.aka dave mole enough said!!!!!
DTV lN CANADA
be quiet....
BE QUIET !!!
SHUT UR FUCKlNG MOUTH UP !!!
U LITTLE PIECE OF CRAPP !!!
applebee
DISCLAIMER.....I have absolutely NOTHING to do with jojo49 ......NEITHER I am him.....NOR have had any contact whatsoever with that person.... I even think his nick sounds kinda stupid....
BUT....
I definetly agree with jojo49 in that theres NO FREE RIDE.... if U want www.directv.com U HAVE TO PAY for it...... ONE WAY OR ANOTHER !!!
Username: Jmill1948
Chester, Va
Usa
Post Number: 289
check this out................just look.........
Top View
$22.99
Usually Ships: 24 hours
Product Specifications:
Protocols: T=0, T=1
ISO Rating: ISO-7816 (Parts 1/2/3)
Clock Frequencies: 1.2288MHz / 3.57945MHz / 3.6864MHz / 4.608MHz / 9.216MHz / 18.432MHz
Interfaces: RS-232 DB-9
Power Input: +7.2 to +24VDC @ 200mA
Dimensions: 3.5" x 2.5" x 0.5"
Power/Mode/Data Flow Indications: (6) Multicolored SMT LED's
O/S Supported: Any O/S that supports the RS-232 Standard
Included Accessories:
(1) 6' DB9 Computer Interface Cable
(1) 117VAC/9VDC 300mA Wall Adapter
(4) 3M® Insulated Bump-on Rubber Feet (Installed)
Model: SKU 3441
●Shipping: Free Shipping
Compare at: $280.99
Our price: $269.99
Product Details: This loader we assume that soon,will be the Unit to P4-P5 card, We are in Test. If you have any Questions please e-mail us
True universal ISO-7816 - 1/2/3 compatibility
On board hardware based universal smart card reader/writer
Microsoft® PC/SC compatible (USCT PC/SC Driver Required) .
On board universal smart card diagnostic and recovery system
On board Atmel AT90S2313-10PI Micro-controller For P4-P5 card Test AT90S8515-10PI.
On board (ICP) Atmel programming interface.
Will gain entry to cards previously untouchable by *old* code
Future Unlock updates for Unlocking future Dealer Lock down 3M scripts One unit, one mode, does it all without any re-flashing.
Provides the solution for cards that won't open with existing loaders and programming.
Repairs otherwise un-glitchable card.
One switch mode selection.
All matched and hand selected device components
No hardware device drivers needed in direct RS-232 mode
Supports all speeds of serial communication up to 115,000 baud
Compatible with all MCU smart cards and most Memory Only cards
Compatible with all RS-232 smart card development software
Supports both commercial and military power specifications
Only true hardware based universal all-in-one S-C terminal available
Amphenol "snap-in" card slot rated at 200K+ insertions
Incorporates the exclusive and convenient SDLOGIC ON/OFF switch
Incorporates a 20-pin dip socket for easy removal of Atmel chip
Incorporates a 4 position switch selector for modifiable timing slopes
Incorporates the proven SDLOGIC INTERSIL RS232 Chip
Incorporates a new heavy duty DC jack
Incorporates a new surface mount heavy duty voltage regulator
Incorporates (5) separate Philips74Hc4053N
Separate mode indicators
Atmel Pin 1 Jumper Enable/Disable /Bridge.
Enhanced high-speed buffer circuitry support (Jumper Enable/Disable)
New anti-static/chemical coating treatment to the Amphenol card slots
BIG SCAM
Username: Jmill1948
Chester, Va
Usa
Post Number: 295
you believe so?
IM 100% POSITIVE
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2004 > Programmers and Cards [ « Previous ] [ Next » ]
