Home > Message Board > Home Video > TV Basics > Archive through October 13, 2004 > Backup RCA 27" Component Video Input
Author Thread: Backup RCA 27" Component Video Input
Username: Cam_t
alright, i just purchased a new RCA 27" TV (im not sure of the exact model, but it has component video inputs in the back, and is NOT flat screen)
now, i also purchased a set of component video cables to connect my DVD player to the TV.
however, i dont have a clue as to how im supposed to get the TV to switch to the channel to receive the component signal.
Edit: ok, i found the tv i have, heres the address
http://www.amazon.com/exec/obidos/tg/detail/-/B0000BZH5H/qid=1095647280/sr=1-2/r ef=sr_1_2_etk-electronics/103-4096911-2284610?v=glance&s=electronics&n=172282
the question is, how do you change the television to the component video signal?
Username: John_s
Columbus, Ohio
US
Post Number: 212
Cameron:
There's most likely an "input" button on the remote. One of the accessories that came with the TV called the "users manual" has the answer to your question.
rca all the way
Cameron, here are two ways to set up your tv to play dvd thru component:
1st way- turn on your dvd player. Then on your RCA remote, hit input until "VID2" appears. Now you can play dvd thru component
2nd way- this way is called auto tuning and will automatically go to "VID2" when you press the dvd button on your RCA remote
1) press MENU on RCA remote
2) highlight Setup and press OK
3) highlight Auto Tuning and press OK
4) highlight Set DVD and use the right arrow button to select VID2 and you are done. Now all you do to watch dvd from now on is turn on the player, then press DVD on your RCA remote
Home > Message Board > Home Video > TV Basics > Archive through October 13, 2004 > Backup RCA 27" Component Video Input [ « Previous ] [ Next » ]
