Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2004 > Dish satelite
Author Thread: Dish satelite
Hello,
I have trouble getting a signal
Tried a dishnet dish with 2LNBs and switch 21W
and when I check switch it gives me no switch detected, so tried a 1 lnb directv dish which I know works, to no avail, set ( I guess ) on 110
using a universaL remote.
getting a red band with unlock and transponder on ??
Even used a sat finder and nothing....
What am I doing wrong ???
am good in DTV but very new with dishnet...grrrr
would appreciate some input..am I missing a step??
thanks m
mmmmm
Username: Timgim
I have Directv what is the best way to set up a terrestrial antenna. and has anyone set up a Mitsubishi WS-55613 with a Yamaha RX-V2090 receiver with a ddp-1 Digital Processor.If so could you please tell me how to wire it.
Moderator
Username: Admin
Post Number: 134
The higher you can place the antenna the better. On the roof or in the attic is preferable. Indoor antennas tend to be hit-or-miss depending on where you live and how far you live from the broadcast towers. Some people have reported good results with the Silver Sensor.
More antenna information is available here:
http://www.ecoustics.com/Home/Accessories/Antennas/
Dish Satelite
It is important when calling or ordering online!
That your Dish Satelite coupon code is R E F 7 7 1 7
You will not receive your Special Online Discount unless you use it!
To Get Your Free Direct TV System
>>>>>>>CLICK HERE<<<<<<<
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2004 > Dish satelite [ « Previous ] [ Next » ]
