Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2004 > P-400 Adapter
Author Thread: P-400 Adapter
Who knows anyting about the p-400 Adapter? I was told it will get up to or over 1000 Channels? Can anyone tell me if it works.
Username: Jmill1948
Chester, Va
Usa
Post Number: 291
check it out.........
Top View
$22.99
Usually Ships: 24 hours
Product Specifications:
Protocols: T=0, T=1
ISO Rating: ISO-7816 (Parts 1/2/3)
Clock Frequencies: 1.2288MHz / 3.57945MHz / 3.6864MHz / 4.608MHz / 9.216MHz / 18.432MHz
Interfaces: RS-232 DB-9
Power Input: +7.2 to +24VDC @ 200mA
Dimensions: 3.5" x 2.5" x 0.5"
Power/Mode/Data Flow Indications: (6) Multicolored SMT LED's
O/S Supported: Any O/S that supports the RS-232 Standard
Included Accessories:
(1) 6' DB9 Computer Interface Cable
(1) 117VAC/9VDC 300mA Wall Adapter
(4) 3M® Insulated Bump-on Rubber Feet (Installed)
Model: SKU 3441
●Shipping: Free Shipping
Compare at: $280.99
Our price: $269.99
Product Details: This loader we assume that soon,will be the Unit to P4-P5 card, We are in Test. If you have any Questions please e-mail us
True universal ISO-7816 - 1/2/3 compatibility
On board hardware based universal smart card reader/writer
Microsoft® PC/SC compatible (USCT PC/SC Driver Required) .
On board universal smart card diagnostic and recovery system
On board Atmel AT90S2313-10PI Micro-controller For P4-P5 card Test AT90S8515-10PI.
On board (ICP) Atmel programming interface.
Will gain entry to cards previously untouchable by *old* code
Future Unlock updates for Unlocking future Dealer Lock down 3M scripts One unit, one mode, does it all without any re-flashing.
Provides the solution for cards that won't open with existing loaders and programming.
Repairs otherwise un-glitchable card.
One switch mode selection.
All matched and hand selected device components
No hardware device drivers needed in direct RS-232 mode
Supports all speeds of serial communication up to 115,000 baud
Compatible with all MCU smart cards and most Memory Only cards
Compatible with all RS-232 smart card development software
Supports both commercial and military power specifications
Only true hardware based universal all-in-one S-C terminal available
Amphenol "snap-in" card slot rated at 200K+ insertions
Incorporates the exclusive and convenient SDLOGIC ON/OFF switch
Incorporates a 20-pin dip socket for easy removal of Atmel chip
Incorporates a 4 position switch selector for modifiable timing slopes
Incorporates the proven SDLOGIC INTERSIL RS232 Chip
Incorporates a new heavy duty DC jack
Incorporates a new surface mount heavy duty voltage regulator
Incorporates (5) separate Philips74Hc4053N
Separate mode indicators
Atmel Pin 1 Jumper Enable/Disable /Bridge.
Enhanced high-speed buffer circuitry support (Jumper Enable/Disable)
New anti-static/chemical coating treatment to the Amphenol card slots
BIG SCAM
Username: Jmill1948
Chester, Va
Usa
Post Number: 293
you think?
IM 100% POSITIVE
Home > Message Board > Home Video > Satellite TV > Archive through September 25, 2004 > P-400 Adapter [ « Previous ] [ Next » ]
