Home > Message Board > Portable Electronics > Portable DVD Players > Archive through April 09, 2006 > Unlock for Goodmans GDVD84WLC?
Author Thread: Unlock for Goodmans GDVD84WLC?
Username: Chugo101
Can anyone help me with the unlock for the Goodmans GDVD84WLC to make it multi region. Thanks for your help.
go to www.dvd365.net click on hacks then goodmans gdvd-122 follow instructions
Rolando
Ah well done. It's taken me a while to find the right one.
David_UK
Hi, what do you think of the player ?
i have burned a dvd+r and dvd-r but can't get either to play on GDVD84WLC. has anyone else had the same problem?
steve_eeee
hi i got the gdvd67w2lcd 2day,instructions are not
in there on how 2 get the screen the right way back up,any ideas
Hi i have a goodmans portable dvd player but i cannot play region 2 disks. I can play copied disks and im not sure about other regions. Have i been sold the dvd with the wrong region code or is it faulty
Hi, I have a GT51N4DVD Goodmans; is there any way of making it Multiregional? Thanks
The region hack for the Goodmans GDVD67W3LCDK (7 inch model) is the same as the 8 inch model.
As found on http://www.dvd365.net/ [hacks]
* Press Set-up on remote and an on screen menu will appear
* Press Next, Previous, Next and Previous
* "2" should appear in the top right hand corner of the screen. Use Right and Left buttons to change this to 255 which is multi regional
* Press Set-up again and you’re done
This worked for me first time.
Username: Dimples
HEY EVERYONE!!!
having a problem finding the right unlocking code for my T.V/DVD combi can anyone help???
It is a goodmans gtv51n2dvd and i can't find a code anywhere. Before anyone suggests it i have tried www.dvd365.net and most other sites but still found nothing. will you be the first to crack it???
Home > Message Board > Portable Electronics > Portable DVD Players > Archive through April 09, 2006 > Unlock for Goodmans GDVD84WLC? [ « Previous ] [ Next » ]
