Thread: IRiver digital audio player question |
New member Username: Oktraveler
Post Number: 1 Registered: Oct-09
| Posted on Wednesday, October 14, 2009 - 04:17 pm: |
My first post here. I hope I'm in the right thread. Need some help here. I have an iRiver Audio player-iFP-700 series. I've had it for several years and I can not find the CD that came with it in order to download music to the player. I have called the iRiver support twice and you have to leave a message for them to call you back. Imagine that! What kind of support is that? Not good in my opinion because they still haven't called me back! Anyways...I need to know if there is somewhere I can download it online so I don't have to wait and order one. I'm leaving town in 3 days and want to download new music now. Any suggestions?? Thank you in advance! Oh I might add....I'm computer illiterate, so simple steps would be great! Thanks! |
Silver Member Username: Ieee488
Post Number: 167 Registered: Dec-07
| Posted on Wednesday, October 14, 2009 - 09:07 pm: |
http://downloads.zdnet.com/abstract.aspx?docid=461057 |
Post Number: 2 Registered: Oct-09
| Posted on Thursday, October 15, 2009 - 02:42 pm: |
I'm sorry, I don't understand the reply to my post. I have Windows Vista does this make a difference? I didn't see where I download the software. Like I said...I am computer illiterate. Thanks so much! |
Post Number: 169 Registered: Dec-07
| Posted on Thursday, October 15, 2009 - 05:24 pm: |
What I am saying is to try just connecting up the device and seeing if Windows sees it as just a flash drive where you can copy files to. In other words, no software to install. Otherwise, you are probably out of luck since they aren't providing new drivers. |
Post Number: 3 Registered: Oct-09
| Posted on Thursday, October 15, 2009 - 05:31 pm: |
Thank you! I tried just hooking it up first and it said install CD. Then I got an email from iriver and they sent me the link for Vista but it doesn't work. It downloads as a zip file. It is really frustrating me. I guess I will just have to go buy a new one. I guess that's what I get for not keeping up with the CD. Thanks though. |
Post Number: 170 Registered: Dec-07
| Posted on Thursday, October 15, 2009 - 07:39 pm: |
Unzip the zip file. That's what you are suppose to do. Then double-click on the setup.exe file or whatever it is called in this case. Of course, if you'd rather spend $$ on a new device, that's your right. |
Post Number: 4 Registered: Oct-09
| Posted on Thursday, October 15, 2009 - 11:05 pm: |
How in the world do you unzip it?? Remember I have Vista if that matters. Thanks! |
Post Number: 171 Registered: Dec-07
| Posted on Friday, October 16, 2009 - 12:02 am: |
If you don't know how to do something, Google it. |
